Home > Technical (L322) > Calibrate ACC 2011 4.4 tdv8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8335 |
The IID tool can re-calibrate it, looks like it does what you need..... maybe worth sending Pat at Gap a message and ask..?
25th May 2020 4:41pm |
neilly Member Since: 06 Oct 2019 Location: Oxon Posts: 79 |
Hi Pete,
25th May 2020 4:52pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2537 |
I suspect the sensor is out of alignment. It's mounting has both vertical and horizontal adjustment and I suspect that the sensor isn't pointing directly ahead. Mine is pointing too high because over slight crests it stops sensing the vehicle ahead so I need to remove the bumper and adjust the sensor downwards a little. |
25th May 2020 9:26pm |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 |
Hi Graeme,
26th May 2020 2:17pm |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 335 |
The sensor for your model is located behind the plastic bumper cover on the offside (UK drivers side) of the car. |
26th May 2020 5:57pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35435 |
its more of a black box that contains the radar unit... ... - .- -.
26th May 2020 5:59pm |
This may help...
26th May 2020 6:49pm |
Finally had a chance to take the Fatty out.
4th Jun 2020 10:56am |
