![]() | Home > Maintenance & Mods (L322) > Painting l322 exhaust, Hammerite Paint ok ? |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
Hi all,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8442 ![]() ![]() ![]() |
99% of paints will be fine with the temp the rear box gets to... |
thanks for the replys |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 ![]() ![]() ![]() |
I just sprayed mine Matt black it’s still looking good 18 months on |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
I used some high temp mat black but as others have said it doesnt really get very hot so Im sure any old stuff will do. Current: FF Westminster money pit
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 596 ![]() ![]() ![]() |
High temp matt black spray works great. Surface preparation needed is minimal, just wash with soapy water, use the green (rough) side of a scotch brite sponge while you're at it. Rinse and let it dry.
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 544 ![]() ![]() ![]() |
Used Hammerite smooth satin black on both of ours, one was done nearly a year ago and is still fine. Make sure you prep well and get all the old loose stuff off and feather all of the edges with wet and dry. Drives:
Just to give you some encouragement.......
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8720 ![]() ![]() ![]() |
Did mine with black BBQ paint. It’s all in the prep. The surface must be very clean and free of dirt and dust. There is nothing that can't be fixed with a hammer😜😜
