Home > Maintenance & Mods (L405) > Creaking drivers door hinge - what fix? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16247 |
That picture is the door check strap Ryan... Make sure the torque bolt is tight holding it (as they come loose ALL THE TIME!!!) |
12th May 2020 9:07pm |
Thanks Craig 👍🏻 |
12th May 2020 10:49pm |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 |
Wd40 isn't a lubricant... put some grease on there. |
23rd May 2020 12:08am |
Take your point Brad, have ordered female Torx sockets... so I can grease and tighten Torx bolt at same time
23rd May 2020 5:13am |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
WD-40 has it's uses, mostly for easing but oil or grease needs to be used afterwards.
23rd May 2020 8:31am |
Only used WD as a quick indicator to see if it was dry... have different types of grease too |
23rd May 2020 8:41am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8488 |
I tend to have a can of white lithium grease knocking around which I use for hinges, check straps and the like. Works well, worth giving all the hinges, straps and the like a good squirt with some of that before starting to take anything apart.... There is nothing that can't be fixed with a hammer😜😜
23rd May 2020 10:41am |
Their use of the word "lubricant" is loose at best. Technically any liquid could be called a lubricant. It isn't actually a lubricant in the same way something like grease is. Just get yourself a jar of marine grease. |
23rd May 2020 2:33pm |
Boatmechanic Member Since: 11 Dec 2019 Location: West coast Posts: 89 |
WD40 contains light oil, and is certainly a lubricant. A lubricant with far better lubricating properties for metal surfaces than water. It is not a relevant comparison.
23rd May 2020 9:10pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3724 |
There is nothing wrong with WD40 - it has its purposes - so does grease. The secret is knowing when to use them. They are both perfect for their intended purposes.
23rd May 2020 9:27pm |
Correct, it isn't a lubricant in the way grease is... which is what a hinge wants. You wouldn't lubricate your boat prop/shaft with wd40, but it is helpful if you're trying to remove it. They all have their uses. |
23rd May 2020 10:23pm |
Ryan, i wouldn't grease your door check strap as this will give the door less resistance! This will mean the door will keep closing on you!
23rd May 2020 10:44pm |
Slightly loosened the bolt on the door check strap (the one in the middle) by using a female torx socket. When loosened, sprayed some “WD-40 Specialist Range - High Performance PTFE Lubricant”. Then tightened the bolt and hey presto, noise gone 👍🏻 |
26th May 2020 7:45pm |
johnf Member Since: 16 Nov 2012 Location: Nottinghamshire Posts: 84 |
I have the same problem. Don't have any torx sockets though. To save me ordering a whole set can anyone tell me what size I need? Thanks. |
29th May 2020 4:21pm |
