![]() | Home > Technical (L322) > Intermittent no crank after turning to pos 3 TD6 |
JohnK Member Since: 15 Mar 2020 Location: Hampshire Posts: 61 ![]() ![]() ![]() |
Ignition barrel problems are common and not too hard to change, just some fiddly clips / screws.
mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99 ![]() ![]() ![]() |
Now you meantion it I did have a similar issue of a skoda fabia vrs,
No Blade needed, you only replace the switch part, not the actual barrel. From memory it just clips / screws together
ok i'll take a look.
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 ![]() ![]() ![]() |
As said its bottom part of barrel easy to swap i did mine and got the part from duckworth landrover |
what about the shifter, the manual doesnt say anything about removing that.
