Home > Technical (L322) > Intermittent no crank after turning to pos 3 TD6
mazza7282
United Kingdom 2003 Range Rover SE Td6 Adriatic Blue
Hi all
My Td6 has an interesting starting issue. When you insert the key, you hear the steering lock disengage, I usually turn it to position 2 to allow the car to initialise and the fuel pumps prime up for 5 or so seconds which also allows enough time for the glow plug light to come on and go off.
When I move from position to 2 to 3, Two things happen it either doesn't allow me to turn to position 3, to engage cranking to start the engine "or" the ignition barrel allows me to turn it to position 3 but the car does not crank over, almost as like you've got a flat battery, but it isnt. The dashboard is all lit up, radios on etc. Repeat this saga 2 or 3 times and the car cranks over and starts like nothing ever happened.
It does this sometimes once every few days or many times in a day
I've read similar posts on this forum relating to an ignition barrel but the issues were being displayed like mine
Is it common for the ignition barrel to go in these ? I didnt know whether the car was immobilising itself, hence me locking unlocking the car.
I've read it with CARLY and nothing is being displayed, its been elsewhere today at a diesel specialist for a read of the fuel pressures for something else, and no faults were present relating to this
Video on youtube which occured this mornin
Cheers
Post #554379 18th May 2020 8:32pm
JohnK
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Ignition barrel problems are common and not too hard to change, just some fiddly clips / screws.
When it is running, check the battery voltage, if it's not 14+v you could have earthing or alternator issues too. Mine had both barrel and earthing and both had similar symptoms.
Post #554424 19th May 2020 7:25am
mazza7282
Now you meantion it I did have a similar issue of a skoda fabia vrs,
there was an obvious wire break to the starter motor. where
power to the vehicle and intermitant crank, but would always allow
me to engage position 3 on the ignition barrel.
This looks like the genuine OE part
https://www.britishparts.co.uk/range-rover...itch-p8103
How about the blade, will I need to get another one to fit the new barrel or ?
Many thanks
Post #554429 19th May 2020 7:59am
JohnK
No Blade needed, you only replace the switch part, not the actual barrel. From memory it just clips / screws together
You can get good quality aftermarket parts for half that price, I used Green Oval sales and Spares as they are local to me.
Post #554430 19th May 2020 8:01am
mazza7282
ok i'll take a look.
Ive looked a the procedure on RAVE, looks simple enough just fiddly.
Post #554889 22nd May 2020 3:39pm
Johnsd1v8
United Kingdom 2004 Range Rover Autobiography Td6 Zambezi Silver
As said its bottom part of barrel easy to swap i did mine and got the part from duckworth landrover
Post #554919 22nd May 2020 6:38pm
mazza7282
what about the shifter, the manual doesnt say anything about removing that.
Is there enough flex to get to the ignition switch then or has the whole centre console gotta come out, shifter included ?
Post #554940 22nd May 2020 9:29pm
