Home > Technical (L322) > TDV8 Vogue 58 plate
Simon_CSK
United Kingdom 2008 Range Rover Vogue TDV8 Adriatic Blue
TDV8 Vogue 58 plate
I have just bought the above vehicle as a non runner knowing very little about the car as it was seized by the police probably for no insurance.
When I collected it the vendors said that they had attempted to get it started and had got the dash light on and by running a wire from the starter to the battery managed to get it crancking over almost starting but obviously with the immobiliser stopping it.
I literally have just got it home and connected jump leads on it. The remote will activate the door locks but there are no dash lights at all and the key does nothing.
Can someone point me in the right direction to start fault finding? Obviously the first thing I need to do is power up the dash so that would imply that the feed to the ignition is either broken or interumpted by the cars security. Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #554891 22nd May 2020 3:51pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
I'd charge the battery first. I've had doors unlock but no dashlights at all with a flat battery.
Post #554900 22nd May 2020 4:31pm
Simon_CSK
Giles
Hopes raised that it could be that simple unfortunately tried it with another battery with no luck Current cars
Range Rover CSK
Discovery 3 HSE
Post #554913 22nd May 2020 6:12pm
DrRob
Fault codes read? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #554916 22nd May 2020 6:28pm
Mikey
Dees the park brake light illuminate?
Post #554924 22nd May 2020 7:40pm
When you put the key in the lock I’m sure that you can hear the steering lock disengage? There is nothing that can't be fixed with a hammer😜😜
Post #554926 22nd May 2020 7:59pm
Simon_CSK
No nothing Current cars
Range Rover CSK
Discovery 3 HSE
Post #554934 22nd May 2020 8:22pm
Simon_CSK
The steering lock is disengaged even with the key out. Current cars
Range Rover CSK
Discovery 3 HSE
Post #554935 22nd May 2020 8:24pm
It sounds like something has been unplugged, have you been round all the cubbies and ECU compartments toncheck that all the plugs are home.
Also check the BCM module which I think is under the front seat. There is nothing that can't be fixed with a hammer😜😜
Post #554938 22nd May 2020 8:47pm
Simon_CSK
DrRob wrote:
Fault codes read?
Can't do that because it will not power up Current cars
Range Rover CSK
Discovery 3 HSE
Post #554969 23rd May 2020 8:15am
Mikey
Does it power up the dash with the little button on the kick panel, next to the OBD port?
Post #554986 23rd May 2020 10:14am
Simon_CSK
Mikey
Thanks went out in the pi**ing rain and found the button. Got the lights and radio on and it allowed me to close the drivers door window.
Progress. Current cars
Range Rover CSK
Discovery 3 HSE
Post #554989 23rd May 2020 10:54am
Mikey
Now, with that button pressed, does the car start?
Post #554991 23rd May 2020 11:11am
Simon_CSK
No unfortunately not Current cars
Range Rover CSK
Discovery 3 HSE
Post #554992 23rd May 2020 11:12am
Mikey
Time to break out the multimeter, and begin testing the ignition fuses and feeds, I think
Had one in this week with a faulty switch
Post #555007 23rd May 2020 12:49pm
