Home > Technical (L322) > TDV8 Vogue 58 plate |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
I'd charge the battery first. I've had doors unlock but no dashlights at all with a flat battery. |
22nd May 2020 4:31pm |
Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 131 |
Giles
22nd May 2020 6:12pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Fault codes read? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
22nd May 2020 6:28pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1753 |
Dees the park brake light illuminate? |
22nd May 2020 7:40pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8510 |
When you put the key in the lock I’m sure that you can hear the steering lock disengage? There is nothing that can't be fixed with a hammer😜😜
22nd May 2020 7:59pm |
No nothing Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
22nd May 2020 8:22pm |
The steering lock is disengaged even with the key out. Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
22nd May 2020 8:24pm |
It sounds like something has been unplugged, have you been round all the cubbies and ECU compartments toncheck that all the plugs are home.
22nd May 2020 8:47pm |
Can't do that because it will not power up Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
23rd May 2020 8:15am |
Does it power up the dash with the little button on the kick panel, next to the OBD port? |
23rd May 2020 10:14am |
Mikey
23rd May 2020 10:54am |
Now, with that button pressed, does the car start? |
23rd May 2020 11:11am |
No unfortunately not Current cars
23rd May 2020 11:12am |
Time to break out the multimeter, and begin testing the ignition fuses and feeds, I think
23rd May 2020 12:49pm |
