Home > Technical (L322) > 4.2 SC lean codes |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 399 |
Unfortunately I don't have ssd but just a bog standard bt adapter. Am tempted to just purchase a gap idd tool though |
15th May 2020 5:20pm |
roverguy7 Member Since: 15 May 2020 Location: Virginia Posts: 14 |
The iidtool is fantastic, but I don't think it will show the adaptive trim tables, I've only ever seen that on SDD.
15th May 2020 5:47pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Hi rover guy just going to hijack for a minute as you seem to know your stuff.
15th May 2020 11:03pm |
Dan, don't worry about spikes when you're looking at live data, your trims should move around as you drive, it's a balance between short, long and sub-feedback trims. If you're only looking at one, you're not getting the full picture.
16th May 2020 4:29pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Dan, post cat sensors just check the efficiency of the cats, they have no effect on fuel trims.. Pete
16th May 2020 4:37pm |
Haylands, that really isn't true for these engine management systems (page 11 has a better description than I'll make) but was correct for earlier systems.
16th May 2020 4:53pm |
May be worth getting some downstream ones then as I’ve done upstream Current stable:
16th May 2020 10:13pm |
Probably won't be the DS sensors at fault, since they're regular O2 sensors, it would normally throw a sensor fault before a fueling fault.
16th May 2020 10:42pm |
Everything is denso - it’s just running slightly rich most of the time as I say its only a couple of percent maybe that’s just ages as it drives great with no faults - maybe I’m looking into it too much just wondered if changing those two would get it bang on Current stable:
17th May 2020 7:20am |
ive got crap maf replacement tbh given a denso is like 80 quid |
17th May 2020 5:21pm |
I'm in the US, but can usually find the Denso sensor for cheaper than that, Denso PN 197-6020 is what to look for. There's also a chance that the rest of the work might have taken care of the initial issue, and a cheap MAFS is at fault now (again, slightly shooting in the dark here without an adaptive trim table) But, if you still have the original MAFS, might be worth tossing it back on and seeing what happens?
17th May 2020 6:23pm |
The new maf has only been on two weeks max. Realistically I need a definitive way to reset the adaptations. So tempted to drop cash on the iid tool
17th May 2020 6:32pm |
bit of an update. my trims at idle are actually decent, they used to be really crap, but my trims are 2.5k-3k are like 20% |
19th May 2020 12:11pm |
Get a maf why don’t you message rob at duckworths on here and get a price with the forum discount Current stable:
19th May 2020 7:45pm |
