Home > Maintenance & Mods (L322) > Deployable step goes up then down?
Danwilderspin
As the video says:
Car went to the garage i took the steps off before hand (just the 4 Allen bolts either side) came back today put them on tight as they were now the passenger side makes a chuff chuff noise when going up and gives up and comes down. Any ideas? Could I Censored up such a simple task? Do they need greasing if so where? They are about 3 years old maybe a little older and never had any maintenance
Thanks Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #553098 7th May 2020 7:54pm
dhallworth
Sounds like the mechanism needs to be cleaned or lubricated.
There is probably an overload on the motor that thinks the step is jamming on something so it pushing it back out rather then letting go all the way in. When you help it with your foot it probably doesn't trigger the overload so allows it to fold.
I'd have a look at cleaning and lubricating all of the moving parts, failing that, taking it off, and cleaning the motor, etc. before refitting.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #553122 8th May 2020 12:28am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Has the step located properly on the bracket? It has to sit in the square / oblong location point under the step and they can be a tight fit, if it’s not located it may foul on the sill. Failing that could be seized hinge pin, rear one is quite common.
Post #553136 8th May 2020 8:46am
Danwilderspin
Yea it it however both sides didn’t not sit flat on the front and back points at the same time not sure if the warp or bend over time but I had to loosely put all 4 bolts in and slowly wind them down Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #553155 8th May 2020 10:10am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Dan,
Search 'Deployable' and 'wedge' you should find threads about setup etc
Smile
https://www.fullfatrr.com/forum/topic49826.html?highlight=wedge
EmiratesA380 is the man -- have a read Wink Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #553156 8th May 2020 10:26am
diesel Dave
Have you put the steps on back to front, IE the left step on the right of the car and vice versa. I notice on your video the three chrome strips meet in the middle of the front door, they should meet between the doors so you don't step on the bald piece. See how this one is different.
Post #553208 8th May 2020 10:06pm
Dan, unscrew the bolts then give the steps a damn good hit downward (like your stepping on them) as im guessing they have not seated all the way home on the oblong plinth Thumbs Up
Post #553210 8th May 2020 10:50pm
Danwilderspin
I think diesel Dave might be onto something here - the mechanism is obviously in the right place or the wiring wouldn’t reach but steps could easily have accidentally been swapped - that’s a job for this morning after my bike ride I think Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #553223 9th May 2020 7:59am
Im sure you cannot put them on backwards! They would interfere with the wheel!
Post #553255 9th May 2020 2:30pm
Danwilderspin
Nope Craig you can as I’ve just witnessed the opposite step from the opposite side was on. The locating pins are slap bang in the middle so it wouldn’t cause any harm. I loosened all the bolts out the step on tight then tightened up. No jamming but still the chuff chuff noise going up so took the step off and it still does it no step? Sprayed a load of copper grease everywhere... still the same put the step back on still the same.any ideas? It’s usable for now as it’s not jamming but that sound doesn’t sound too clever... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #553268 9th May 2020 4:04pm
diesel Dave
I would take the step off again, there is a rod going from the motor to the rear bracket, it has a 10 mm bolt securing it just before the bracket. Remove the bolt and work the hinge by hand, if its the slightest bit tight that’s your problem, spray with duck oil or similar and work it by hand a million times till it’s free. I used to have to do mine after most winters to keep them working ok. You’ll be surprised how little resistance stops them operating properly.
Post #553273 9th May 2020 5:06pm
Danwilderspin
Well so far so good although it didn’t sound much better yesterday I think the grease may have worked in over night as it’s nearly back to normal today Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #553357 10th May 2020 4:59pm
Garnerj
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
I had the same on the wifes 2011, a bit of grease underneath and all good since. Smile Thumbs Up
Post #553362 10th May 2020 5:27pm
