Home > Maintenance & Mods (L322) > Auto Electrician needed |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Anyone know of a good electrician I need to have a fault in the loom found Ta |
5th May 2020 7:47am |
Dizzy Dee Member Since: 26 Dec 2017 Location: London Ish Posts: 96 |
Yes, but in Croydon, so not too far from you.
5th May 2020 6:18pm |
Its an interesting one the heated seats have stopped working so swapped out the switch pack still the same did put it in to na indie who found a broken wire and it worked for a few days but stopped again - I also have an airbag light which appears and disappears on the 11d tool diagnostics nothing but did have an odd suspension fault so my guess is a wire has a bad connection somewhere near the ignition switch so need a sparky to go through it all and find it |
5th May 2020 6:46pm |
Yes must admit have been disappointed with what I have found so far - there are a lot of taped slices nuts |
10th May 2020 5:43pm |
