Home > Technical (L405) > Soft Close door not woking. Common? DIY fix?
FTP20
United States 2015 Range Rover 5.0 SC V8 Fuji White
The Soft Close driver's door on my 2015 FFRR hasn't worked since I purchased the vehicle second-hand. Is this a common issue and is there an easy way to repair it?
Post #553123 8th May 2020 3:16am
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
I had same problem with mine when picked up
apparently they disable the drivers door in transit - there is a plug & socket in the rear by the spare wheel that needs plugging together again - did mine only took 2 mins
this is the link from rangerovers.net
http://goo.gl/bS75e1
last pictures show location - the plug is under the black tape
hope this helps various other LR's this one is still the best
Post #553134 8th May 2020 8:38am
FTP20
Top tip - fixed! Hard to imagine that the previous owner went 4+ years without the soft close working and didn't take it to LR for repair Rolling Eyes
Post #553173 8th May 2020 3:28pm
nice one Phil Thumbs Up ... - .- -.
Post #553174 8th May 2020 3:36pm
sgorianin@gmail.com
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Stan, I would say this topic needs to move to Wiki as it seems to be a common problem.
P.s was trying to find the problem myself where spent 5 days to trace power leads into the boot section. And only 2 minutes to Google this problem...
Post #711938 15th Feb 2025 10:11pm
alaska1993
Romania 2016 Range Rover Vogue TDV6 Santorini Black
Thank you! I just brought home my MY 2016 AB and the soft close doors didn’t work. Two minutes and all works perfectly. 😁
Post #714935 26th Mar 2025 1:51pm
Gremlin500
Great when you find an easy fix! Thumbs Up
Twisted Evil For those who end up here and it’s not the solution, check out the recent YouTube video from LR Time, where Christian Bow down addresses a more complex cause of the same issue, but you’re going to have to take a brave pill! Rolling with laughter “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #714936 26th Mar 2025 1:57pm
alaska1993
I know. So happy. It’s hard to believe someone left it that way for 9 years. I just watched that same video as well and was holding my breath. I’d sooner qualify for the space program that successfully complete that repair. Mine is identical to Christian’s except mine is a 2016. I love their channel. They, and Margot Robbie, helped me name my RR. I was thinking of “the queen” when I saw the Wolf of Wall Street clip from when Jordan meets the Dutchess of Bay Ridge. Bam! “The Dutchess”.
Post #714938 26th Mar 2025 2:13pm
Gremlin500
FWIW, you DO have to qualify for the space programme to complete that repair. Shocked
I can imagine NASA calling Christian if they get an unfixable problem on the Space Station.
The challenge will be getting his lathe up there….. Whistle “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #714941 26th Mar 2025 3:35pm
Wilkco66
United Kingdom 2015 Range Rover Autobiography SDV6 Mariana Black
Unbelievable!! My2015 AB had it about a month. Drivers door soft close didn't work. I Thought it can't be that. 10 minutes later plug connected in the wheel well, fixed. Thank you for the information 🙏
Post #714953 26th Mar 2025 8:20pm
