Home > Technical (L322) > L322 4.4 tdv8 2010 transmission module |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2485 |
It is inside the gearbox. |
6th May 2020 8:45pm |
Shawser1203 Member Since: 29 Jul 2017 Location: Aberdeenshire Posts: 88 |
So not easy to get to then? |
6th May 2020 9:06pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 968 |
You miss the point. ZF moved it inside the transmission so that there aren’t any wires to corrode or come loose. It’s part of the Mechatronic unit, which is made up from two modules. One is a ‘standard’ valve block assembly – the hydraulic module - and the other is an electronic module which contains the ECU.
7th May 2020 8:45am |
Cheers Phil.
7th May 2020 9:05am |
P279D-02 four wheel drive range signal circuit, general signal failure. |
7th May 2020 9:11am |
That suggests a transfer case or ecu problem. |
7th May 2020 9:42am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Take it to MMP in Dundee maybe for investigation? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
7th May 2020 12:02pm |
