![]() | Home > Off Topic > Foam lance for hose |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 743 ![]() ![]() ![]() |
I have a Gilmore foam master, it's supposed to be one of the best for a hose but I think its a bit more than the one you linked to. 2021 P400 Silicon Silver AB
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 ![]() ![]() ![]() |
In stock and delivered from here:
The foam applicator in your link isn't much use, they don't work that well. If you want one for a hose then the Gilmour Foamaster is the one to go for, although not the price you are looking at.
Royle Member Since: 12 Nov 2010 Location: Perth Posts: 655 ![]() ![]() |
Thanks, I'll sleep on it and see what I can justify spending. Probably end up going for the Gilmour, but I'll have to see |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2050 ![]() ![]() |
Nilfisk cheap enough here:
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
Is this the pressure washer you have mentioned?? http://www.amazon.co.uk/Nilfisk-X-Tra-Pres...amp;sr=1-1 Is it any good?? FFRR TD6 HSE Adriatic Blue with Parchment leather. |
Greg
ah yes, thanks Nigel. Is that little plastic bottle sufficent to use with the snow foam or would I need to buy another part?? FFRR TD6 HSE Adriatic Blue with Parchment leather. |
Greg
Greg
got it, so I'll just need to insure the foam lance I go for fits a nilfisk pressure washer?? FFRR TD6 HSE Adriatic Blue with Parchment leather. |
Greg
Thanks again
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
hi i have a Karcher foam lance that can be used with a hosepipe AND pressure washer you can have it FREE of charge (used once) to use with a hose you need to buy the Karcher to Hozelock adaptor at about £5.99 if you want it just PM me your address shame your so far away as i have two mint Karcher pressure washers for sale - small K 2.35D and a larger K3.99M note to self - stop buying pressure washers ![]() |
