Home > Off Topic > Foam lance for hose
Royle
Foam lance for hose
Does anyone have recommendations or know of a foam lance which fits on a hose. I haven't got a pressure washer and can't be bothered to get one at the moment. I looked at THIS but it's out of stock. Something similar to it with a similar price would be preferable.
Royle
Post #55251 17th Mar 2011 7:27pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
I have a Gilmore foam master, it's supposed to be one of the best for a hose but I think its a bit more than the one you linked to. 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #55253 17th Mar 2011 7:46pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
In stock and delivered from here:
http://www.performancemotorcare.com/acatal...#aPMC00603
Thumbs Up My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #55254 17th Mar 2011 7:47pm
The foam applicator in your link isn't much use, they don't work that well. If you want one for a hose then the Gilmour Foamaster is the one to go for, although not the price you are looking at.
You would be better spending a few pounds buying a Nilfisk 110 powerwash and an HD Foam Lance which will give much better results
Post #55256 17th Mar 2011 7:53pm
Royle
Thanks, I'll sleep on it and see what I can justify spending. Probably end up going for the Gilmour, but I'll have to see Thumbs Up
Post #55258 17th Mar 2011 8:04pm
nbunney
Nilfisk cheap enough here:
http://cpc.farnell.com/nilfisk-alto/c110-3...dp/SI15531
And for the foam lance give Micheal a ring here:
http://www.thepolishingbooth.com/
Say Nigel put you his way and he might do you a deal. He also sells anything else you may want to keep your car looking Thumbs Up
Post #55263 17th Mar 2011 8:23pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Is this the pressure washer you have mentioned??
http://www.amazon.co.uk/Nilfisk-X-Tra-Pres...amp;sr=1-1
Is it any good?? FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #55265 17th Mar 2011 8:34pm
nbunney
Greg
Same as the 1 I posted, but with the Patio attachment
Post #55268 17th Mar 2011 8:39pm
GregP
nbunney wrote:
Greg
ah yes, thanks Nigel. Is that little plastic bottle sufficent to use with the snow foam or would I need to buy another part?? FFRR TD6 HSE
Post #55270 17th Mar 2011 8:44pm
nbunney
Greg
You do need a foam lance, that little bottle is as much use as a Censored
Post #55271 17th Mar 2011 8:50pm
nbunney
Greg
Post #55272 17th Mar 2011 8:50pm
GregP
nbunney wrote:
Greg
got it, so I'll just need to insure the foam lance I go for fits a nilfisk pressure washer?? FFRR TD6 HSE
Post #55273 17th Mar 2011 8:52pm
nbunney
Greg
For the foam lance give Micheal a ring here:
He's sorting mine out Thumbs Up
Post #55276 17th Mar 2011 9:05pm
GregP
Thanks again
I'll prob just drop him an e-mail tomorrow. Thumbs Up FFRR TD6 HSE
Post #55282 17th Mar 2011 9:27pm
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
Re: Foam lance for hose
Royle
hi
i have a Karcher foam lance that can be used with a hosepipe AND pressure washer
you can have it FREE of charge (used once)
to use with a hose you need to buy the Karcher to Hozelock adaptor at about £5.99
if you want it just PM me your address
shame your so far away as i have two mint Karcher pressure washers for sale - small K 2.35D and a larger K3.99M
note to self - stop buying pressure washers Whistle
Post #55382 18th Mar 2011 11:08am
