Home > In Car Electronics (L322) > l322 2003 voice & phone
Page 1 of 4 1234>
tommo10ferrets
England 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Afternoon all, Would anyone near me (Leicestershire) have the original phone & voice installation fitted in their car or the upgraded Bluetooth installation for a 2003 RR that I could possibly come & look at ? I know its a big ask, but there is so much information out there that I've confused myself & I think actually looking at the installation would enable me to fully understand what is required. With thanks.
Tommo
Post #552155 30th Apr 2020 2:08pm
mjdronfield
Can’t help with the specific ask as I don’t have my early L322 anymore....but.....
The big black 54 pin plug in the back of your car will need repinning.
You will need to buy a BMW ULF unit. If it says MIT SES on the label, it will also do voice commands.
You will need a Bluetooth antenna for the ULF.
You will need a microphone.
The antenna lead and the microphone lead that goes from the back to the front should already be in your car.
That’s all there is to it.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #552157 30th Apr 2020 2:21pm
tommo10ferrets
Thank you for the info, it's appreciated I'll go on line & see what I can find.
Regards
Tommo
Post #552163 30th Apr 2020 3:04pm
tommo10ferrets
Hello Again, would the attached photos be the right units I require ? already have a microphone. Thank you.
Post #552176 30th Apr 2020 3:59pm
mjdronfield
That looks just the job. Will do voice too.
The antenna goes on the 2 bolts sticking up from the frame on top of the sat nav unit.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #552184 30th Apr 2020 4:26pm
tommo10ferrets
Thank you, really appreciate your help.
Tommo
Post #552192 30th Apr 2020 4:50pm
tommo10ferrets
ulf retro fit
Afternoon all, just a quick update with regards to the fitting of the ulf module, it arrived this morning, I swopped the pins required to suit the ulf module on the wiring loom plug, plugged it in & telephone is now showing on the head unit screen, when highlighted, pushed enter button, "Activate phone" now shows on screen, I presume this means some how accessing hidden menu & activating? The antenna & lead have not arrived as yet, hopefully in the next day or two, I have still to fit the steering wheel voice button, will do that one day next week. On the wiring loom, near the 54 pin plug, there is a flat 5 pin plug (male end) 2 x black wires, 1 x red wire 1 x white wire & 1 x grey wire (think that's what the colours are off the top of my head) does anyone know what this plug is ? the female plug end is already part of the existing wiring loom. Will have to try & finish installation next week, as I have been given the ok to go back to work the following week, have been furloughed since March.
Post #554066 16th May 2020 1:23pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Just been doing this to my 2003, if you punch in bluetooth upgrade to the search box top of the page that will get you started then just keep following the links as they pop up (loads of them, thats what I have done) you might have to bridge some wires on the voice control unit (silver box bolted under satnav) I have even done the mod on the eject box (thank you @ p38arover) did have problem mounting the ulf because the cable is at right angles to the box, in the end I cable tie it low down on its side.
Post #554121 16th May 2020 8:33pm
pcourtney
best advice is to get the latest 13th gen models, I had trouble with earlier ULF's, but the one I have now is dated MEX 07-08-2008, and I think 84 10 9 154 358 and later are the 13th generation units
mine is 84 10 9199976
https://store.bimmernav.com/blogs/installa...lf-modules
Post #554132 16th May 2020 10:31pm
pcourtney
the secondary NAD ( Purple ) is for an external mobile phone antenna ( Shark Fin on the roof )
NAD = Network Access Device
Post #554135 16th May 2020 11:29pm
tommo10ferrets
Ulf upgrade
Morning both, thank you for your replies & info, the unit in the photo below, is that the 13th edition module ? if so, its very different from the 8th edition I have got, more connectors. My car is a 2003 vogue, I was led to believe that they were all pre-wired for phone /voice, the only pre-wiring I found was the overhead microphone, nothing in the boot, no loom connected to the large white 12 pin plug in the boot, no voice module etc, so I bought a phone loom & voice module( which I later found out wasn't required, as the mit ses has voice built in) In other post's its saying the pins 32 & 36 need to be connected to allow pairing(will be looking at this today), on the loom I have bought at the end of it is a plug (similar to the 54 pin plug, but smaller) this I presume went to the eject box(which I haven't got) now, near to this is a little 3 pin plug, would this have gone to the pairing button ?, if so, it may be possible to be modified to act as a pairing switch, I will trace the wires from it & see where they go to in the loom, then again might be for something completely different, i'll see.
Regards
Tommo
Post #554165 17th May 2020 9:23am
kds2
Sorry cant help much more with this, my car had the full works regards the in car phone I just started searching bluetooth threads and book marked them when found to refer to, mine had an after market Nokia bluetooth kit in it when I bought it and having done the reverse camera upgrade, park heating remote switch on, dvd satnav (still got the bmw splash screen though Sad ) and flappy paddle gear change first with the wirless 2 channel remote and then zebadee and damien walker kit (brilliant bit of kit by the way) I thought I would have a go at the phone, gen 5 ulf on ebay for £25 if it goes whatsit up its not cost much, but it works fine and picked up the phone book straight away on my redmi note 7 android phone happy with that, Nokia kit now removed and will pass it on to a friend of mine who just happens to have a work shop with 4 post lift, tyre changer and balance machine Wink like I said in first post search all the bluetooth threads and links and you find the answers, sorry long post.
Post #554387 18th May 2020 8:58pm
mjdronfield
Ok, so Activate Phone is just telling you to turn your phone on as it can’t detect it. That’s because it’s still paired with the phone of the previous owner of the ULF. You need to pair yours to it. Not sure you can do that without antenna.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #554393 18th May 2020 9:20pm
mjdronfield
Pairing wiring query here if it helps...
https://www.fullfatrr.com/forum/topic55154.html 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #554394 18th May 2020 9:24pm
kds2
Now that last link never popped up when I was looking, but thank you @mjdronfield your name kept popping up in my searches and helped me out.
Post #554409 18th May 2020 11:29pm
Page 1 of 4 1234>
