![]() | Home > Technical (L322) > L322 2008 key |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
This WILL set the remotes to work but you will NEVER be able to get it to start the car this needs a programmer like the cn900 mini or other product which can code the immobiliser chip... Current stable:
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 881 ![]() ![]() ![]() |
oh, I see, does the CN900 mini now support L322 model years BMW based 2002 to 2005 ??
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1355 ![]() ![]() |
The bt iid tool does programme some keys but not the 2007 to 2009 variants ime.
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
OK, you don't need the IID to programme the keys as per pcourtney instructions -- the process will work without IID, but as Dan says that simply allows the buttons to work (lock unlock etc) it doesn't programme the chip
Dizzy Dee Member Since: 26 Dec 2017 Location: London Ish Posts: 96 ![]() ![]() ![]() |
Is the 2002-2004 system something for the home user or a pro only device? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2274 ![]() ![]() ![]() |
I have 3 keys one does everything one will open doors and start car but no remote and one just opens doors
Dizzy -- you have to strip bits out of the car to programme.
That's enough information for me. Thank you. |
It isn’t actually that hard - you can get the programmer for a tenner! On Ali express or £20 on eBay. You need to remove the ews module and put the chip plug on the chips it then reads what it needs to you can put it back and with that information you can code as many as you need only 02-05 Current stable:
the EWS is in the centre console
it seems even Powerful UK got stumped by the EWS bit, good video though |
