![]() | Home > Maintenance & Mods (L322) > My other Covid-19 project |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
Good job, always wondered why they put so much under the carpet and so little in the doors and boot floor... Pete
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Mrs old Skoda suffered from booming from the boot at a Cruise. Stuck a load of Dynamat in there and it sorted it. Top idea. There is nothing that can't be fixed with a hammer😜😜
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
I’m not big on this stuff or rather my knowledge is not.
Also how much did you buy? Current stable:
Right this arrived today... boat some closed foam too. Anyway do you cut a sheet any mount it over the window access opening or do a cutout and mount some on the onside of the external skin? Current stable:
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Dan, I've just used that Noico stuff to do my Golf GTI . Used 80 & then 160 closed cell foam on top.
Rob. 2011 (MY12) 4.4 TDV8 Vogue 2016 Golf GTI PP Gone Audi A4 VW Passat VW Corrado G60 VW Golf GTI BMW E30 Mini Vauxhall Chvette |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
I covered as much as I could of the inner side of the outer skin; the back side of the inner skin and the door panel itself. I probably overdone it but rather that than doing a little part of the door and then finding it not doing what I wanted it to do and then having to remove the door panels again.
