![]() | Home > Maintenance & Mods (L322) > My other Covid-19 project |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8531 ![]() ![]() ![]() |
Good job, always wondered why they put so much under the carpet and so little in the doors and boot floor... Pete
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Mrs old Skoda suffered from booming from the boot at a Cruise. Stuck a load of Dynamat in there and it sorted it. Top idea. There is nothing that can't be fixed with a hammer😜😜
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
I’m not big on this stuff or rather my knowledge is not.
Also how much did you buy? Current stable:
Right this arrived today... boat some closed foam too. Anyway do you cut a sheet any mount it over the window access opening or do a cutout and mount some on the onside of the external skin? Current stable:
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Dan, I've just used that Noico stuff to do my Golf GTI . Used 80 & then 160 closed cell foam on top.
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
I covered as much as I could of the inner side of the outer skin; the back side of the inner skin and the door panel itself. I probably overdone it but rather that than doing a little part of the door and then finding it not doing what I wanted it to do and then having to remove the door panels again.
