![]() | Home > Maintenance & Mods (L322) > Painting Calipers |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
I used it on front & rear calipers 6 or 7 months ago - on ours front are 4 pot alloy Brembo & rear cast iron TRW.
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 ![]() ![]() ![]() |
We do have a caravan, but just driving with forward thought and gear braking does the trick.
I gave the front calipers 2 coats. It was so hot when I did the first coat, I couldn't get it to dry smoothly the first time or without thin patches.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
Hammerite smooth, 2 coats |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16311 ![]() ![]() ![]() |
Mine done with two pack car paint which doesn't discolour with heat...
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 750 ![]() ![]() ![]() |
Done in situ with a brush!
Chefkenmore : Brembo stickers off ebay? Paul,
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 250 ![]() ![]() |
Hammerite done in situ, took a few coats mind, but that is down to colour.
Good job! |
Don't think its the colour for me, but look well done. Just need the weather now. Then its fix noise/fit disc and pads with nice finish of paint |
Sorry for the late reply, yes, eBay for the decals |
sumshiftyguy Member Since: 12 Mar 2020 Location: London Posts: 36 ![]() ![]() ![]() |
Reviving an old thread! I'm thinking of refurbishing my calipers as they seem to be in a pretty poor (aesthetic) state from repeated corrosive wheel cleaner use.
Mine are the yellow ones in this thread, done with hammerite 2 years and 40k ago, mine got wire wheeled to get to loose stuff off then brake cleaner before painting.
They get a bit of use, and I tow trailers most days and a twin axle caravan
