Home > Maintenance & Mods (L322) > Painting Calipers
SinbadRose
Painting Calipers
Hi all,
I have read a number of posts, some saying to use caliper paint, some saying to use Hammerite smooth (even though this isn't high heat), all giving one reason or another on which to use.
I want a smooth (as it can be) grey or black that can be done with a brush, don't want to disconnect the caliper fully, or mask off lots of area.
Has anyone used Hammerite smooth and how has it been over time, or would you recommend true caliper paint?
Cheers
Post #486298 16th Aug 2018 5:23pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I used it on front & rear calipers 6 or 7 months ago - on ours front are 4 pot alloy Brembo & rear cast iron TRW.
Managed to get a reasonably smooth finish with a brush - certainly good enough for behind a wheel. I used black & did clean the calipers with brake cleaner solvent after rubbing down with medium roughish gritpaper
Doesn't seem to have deteriorated at all so far - but no alpine descents towing a caravan yet ( or planned - lol).
In normal use, the calipers don't get that hot & if the paint does deteriorate, it's cheap & fast to re-do.
Using it on the front disc bells might not be so positive, but I've used hand painted heat resistant silver there with reasonable results so far. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #486304 16th Aug 2018 6:47pm
SinbadRose
We do have a caravan, but just driving with forward thought and gear braking does the trick.
The discs are already coated but they will be getting a blast of silver (already have it from doing the old ones (bell section only) but will give the Hammerite black (grey if i can find it) a go.
Thanks for the reply, all going well, should have it done over the next weekend or so.
One more thing, did you give the calipers a single or multi coat, and if so, how long to dry before you did the next coat?
Thanks again
Post #486317 16th Aug 2018 7:54pm
Pawl
I gave the front calipers 2 coats. It was so hot when I did the first coat, I couldn't get it to dry smoothly the first time or without thin patches.
The 2nd coat went on a few days later when the ambient temp was more reasonable.
The rears only got 1 coat - although I had used kurust on them a few days previously to neutralise any remaining rust & create a black undercoat .
All done with no masking or disconnection - quick & effective - lol
From past experience if a 2nd coat is required, I've always waited a few hours min. Any less & the 2nd coat appears to pull the 1st off - not ideal ! Paul,
Post #486318 16th Aug 2018 8:16pm
Mikey
Hammerite smooth, 2 coats Thumbs Up
Post #486320 16th Aug 2018 8:27pm
Mine done with two pack car paint which doesn't discolour with heat...
The disc bells and disc outers are coated in a simple Simoniz wheel silver. Have used engine enamel rattle cans before too Thumbs Up
As long as you keep them washed in the winter the disc paint lasts years...
Post #486324 16th Aug 2018 9:12pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Done in situ with a brush!
 2014 vogue se
Post #486326 16th Aug 2018 9:32pm
Pawl
Chefkenmore : Brembo stickers off ebay? Paul,
Post #486328 16th Aug 2018 9:57pm
nearlee
Wales
Hammerite done in situ, took a few coats mind, but that is down to colour.
 Remember:- amateurs built the ark
Proffesionals built the titanic
Post #486336 17th Aug 2018 5:32am
Pawl
Good job! Cool Paul,
Post #486349 17th Aug 2018 7:58am
SinbadRose
Don't think its the colour for me, but look well done. Just need the weather now. Then its fix noise/fit disc and pads with nice finish of paint
Post #486363 17th Aug 2018 9:44am
chefkenmore
Sorry for the late reply, yes, eBay for the decals Thumbs Up 2014 vogue se
Post #486459 18th Aug 2018 10:25am
sumshiftyguy
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Reviving an old thread! I'm thinking of refurbishing my calipers as they seem to be in a pretty poor (aesthetic) state from repeated corrosive wheel cleaner use.
Is anyone able to point me to a write-up as to how to go about doing this without removing the calipers? From this thread I gather:
1. Medium grit rub down (80-120?)
2. Clean down with brake cleaner solvent
Like this? https://www.toolstation.com/holts-brake-cleaner/p43710
3. Metal paint - 2 coats with a few hrs dry time between coats
I see some using high temp paint and others going for standard Hammerite smooth. Has anyone seen one being better than the other in terms of longevity? And would a 250ml tin be sufficient for 4 calipers or should I be getting more? I'm not familiar with it's consistency.
I was thinking of something like this - https://www.amazon.co.uk/Hammerite-5084869...amp;sr=8-5
Or perhaps just go for a VHT caliper paint link this
https://www.amazon.co.uk/Brake-Caliper-Ena...B01HF8RVG0
4. Brembo decals off eBay
http://vi.raptor.ebaydesc.com/ws/eBayISAPI...&ver=0
Did I miss anything?
Post #551365 22nd Apr 2020 9:30am
nearlee
Wales
Mine are the yellow ones in this thread, done with hammerite 2 years and 40k ago, mine got wire wheeled to get to loose stuff off then brake cleaner before painting.
And they still come up looking good even now, and I'm not one for cleaning Rolling with laughter Remember:- amateurs built the ark
Post #551442 23rd Apr 2020 6:37am
nearlee
Wales
They get a bit of use, and I tow trailers most days and a twin axle caravan
Post #551443 23rd Apr 2020 6:40am
