![]() | Home > Maintenance & Mods (L405) > L405 3.0l Remap? |
Beach Member Since: 11 Jul 2015 Location: Bristol Posts: 54 ![]() ![]() ![]() |
Have a look at DMS Automotive, they list your car |
Lordackers Member Since: 28 Feb 2020 Location: West Yorkshire Posts: 32 ![]() ![]() |
Thanks beach |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
it can be done..my son offered to do mine but i'm happy with my tdv6 performance.. ... - .- -.
Hi Stan,
I'm a steady driver so all's ok for me.... ... - .- -.
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
There is a bit of a hole in the power delivery low down, which seems to relate to it being fitted with a single turbo. Try the twin turbo SDV6 in the D4, or the SDV8 in the RR and you’ll probably notice a big difference. Coming from an SDV6, I noticed it straight away although, if I’d never had one before, I may never have thought much of it.
Maccaa Member Since: 03 Feb 2020 Location: Bristol Posts: 38 ![]() ![]() ![]() |
I'm sure I watched a youtube video where a chap was having his L405 tuned by DMS but stated the same problem you have"slow away" and the owner of DMS mentioned that as part of their package they tweak the gearbox software to remove this issue. Apparently RR have built this in to increase the "wafting" effect of the car (not great if you've got a car planted in your drivers door). Would definitely be worth a call, the guy who was having his car tuned said he would have paid the money just for the gearbox mod...... Current FF Westminster 4.4 V8 |
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 ![]() ![]() ![]() |
I added a PedalBox and it eliminated the hesitation in throttle response - especially at roundabouts etc 2017 Range Rover Vogue SE SDV8 (with e-diff)
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
Could you try Sand mode on terrain response on some roundabout exits in case that is enough? It would save the cost, telling your insurers about the modification etc if it did work. Only Range Rovers since 1988 |
Thanks for your comments definitely some ideas to look into |
