Home > Maintenance & Mods (L322) > Crazed/cloudy headlamp lenses
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Hello, my headlamp lenses on my 2008 tdv8 are going cloudy and crazing on the tops where they hide under the bonnet lip, Would it be sensible to sand them down with say 1500grit wet n dry then go on to farecle G3/G10 or will I fubar em🙄? Thanks. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #551397 22nd Apr 2020 2:14pm
Fox889
In the kit I had, if I remember, it started with 800 grit then 1500, 2000 & finished off with 3000. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #551418 22nd Apr 2020 7:06pm
Gsxr1250dave
You dont need to sand them, g3 is ok but mcquires scratch remover is better on glass or plastic lenses
Sorry no before photo but these were pretty yellowish before I started. I do use a machine polisher
Post #551419 22nd Apr 2020 7:17pm
Post #551421 22nd Apr 2020 7:20pm
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
There are kits available on ebay, Amazon etc. They do work very well but you need to be patient, following the process fully and not short cut or rush it. Its also a bit of a leap of faith first time ! lol
Post #551800 27th Apr 2020 10:56am
Rapiscan
Thanks for the advice, wonder if a dual action polisher would, speed up the process? Rolling Eyes 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #551801 27th Apr 2020 11:19am
ur20v
A Trap
Yes, you can use different grades of compound and then finally jewel polishing, clean with IPA then use a proper UV safe clear coat.
If you have a friendly body shop and enough time give them the finished polished head lamps and ask them to give 2 or three coats of clear coat when they are painting another vehicle👍 The body shop/ industry available paints tend to be better than the cheap aerosols available at Halfords etc.
Once hardened give the clear coat a sand to flatten and repolish.
Post #551805 27th Apr 2020 11:39am
WB
Yes a DA would definitely be handy
Post #551838 27th Apr 2020 2:48pm
