Home > Technical (L322) > Flickering leds
Paddocks67
Flickering leds
Hi lads,hope someone can help here,I have upgraded 2010 leds taillight and halo front lights, iam getting problems they just start flickering,front and back if I have them turned on at night,like a disco,also lose indicators lights on dash when check outside the are flashing very slow,when I stop the car the brake lights stay on and the only way to get them off is to disconnect battery,it's becoming a pain in the arse,cheers pat
Post #550866 18th Apr 2020 7:32pm
Probably something to do with the Balast resistors on the rear lights. There is nothing that can't be fixed with a hammer😜😜
Post #550869 18th Apr 2020 7:52pm
have a look at he conversion threads in the wiki or do a forum search, i'm sure theres something on this.. ... - .- -.
Post #550873 18th Apr 2020 8:05pm
Paddocks67
Hi I've changed the resistors on the back lights I bought fix from powerfuluk and I still had the same problem,so sent them back,bought gap iid and turned all lights hot and cold off from lcm,and still happens,can't figure this out at all,as it just happens randomly.is there anything else to check,had the LCMs out that looks fine,just leaned the contacts with contact cleaner,cheers pat
Post #550879 18th Apr 2020 9:53pm
It would help giving some more details on age & model of your car. How you did the conversion or did someone else do it?
Post #550898 18th Apr 2020 11:33pm
Paddocks67
Hi Craig,Isis a 2008 tdv8,I never done the conversion,so don't know how it's neen done it has two resistor boxes on the back lights the front halo,s they have seemed to have connected them via front side lights which are now not operationa,I read somewhere that someone said he turned all the lights off on LCMs and didn't need to use box resistors on back lights,will that work,cheers pat
Post #550945 19th Apr 2020 10:01am
