Home > Maintenance & Mods (L322) > 2012 tdv8 4.4 shock absorbers. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
be aware that you have a adaptive dynamics car so the new shockers will need to be compatible so the cheap ones won't work. From what I can remember there are only a few options. The LR ones are about 350 a side, the aftermarket ones about 300... There is nothing that can't be fixed with a hammer😜😜
18th Apr 2020 9:57pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Have them checked and double checked as they leaked from near new! Many have damp tops but work perfectly!
18th Apr 2020 11:12pm |
As Craig says, they all weep a little bit and show a mist of oil
18th Apr 2020 11:15pm |
sean mullane Member Since: 10 Dec 2019 Location: limerick Posts: 18 |
i think it needs new ones as it rolls like a boat and it hits the bump stops with the slightest bump, on a speed hump the rear lifts really high , thank you for your replies and taking the time to reply ,, sean |
18th Apr 2020 11:19pm |
Seams you are the unlucky one then sir
18th Apr 2020 11:23pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
I replaced my rears with Bilsteins. I felt safe using Bilsteins because their firmness is ecu-controlled. I had Bilstens on a D2 and found them excessively firm but they're fine on the L322.
19th Apr 2020 3:48am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1750 |
Replaced a few over the past while
19th Apr 2020 6:25am |
The bilstein ones are nearly as much as the LR ones. There is nothing that can't be fixed with a hammer😜😜
19th Apr 2020 8:09am |
thank you for your replies and help . i priced main dealer and was quoted nearly 1000 euro per unit. bilstein prices were about 650 euro for both , i ended up buying the shock absorbers from aerosus in germany suitable for variable dampening costing 450 euro for both.. |
26th Apr 2020 3:07pm |
LRDirect had he LR ones at 350 per unit, but 450 for both seems decent, let us know how you get on with them There is nothing that can't be fixed with a hammer😜😜
26th Apr 2020 3:19pm |
Aerosus shock absorbers fitted. Fantastic difference to the driving of the Range Rover . Beautiful handling on all types of roads , |
30th May 2020 1:53am |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
Might get some for mine. How many miles on yours? 1995 4.6 v8, green/tan (long gone)
30th May 2020 11:52am |
160000 miles -200000 km |
8th Jun 2020 10:19am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
160 000 mi - 257 000 km 2012 TDV8 Black Edition
9th Jun 2020 9:44am |
