![]() | Home > Maintenance & Mods (L322) > 2012 tdv8 4.4 shock absorbers. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
be aware that you have a adaptive dynamics car so the new shockers will need to be compatible so the cheap ones won't work. From what I can remember there are only a few options. The LR ones are about 350 a side, the aftermarket ones about 300... There is nothing that can't be fixed with a hammer😜😜
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Have them checked and double checked as they leaked from near new! Many have damp tops but work perfectly!
As Craig says, they all weep a little bit and show a mist of oil
sean mullane Member Since: 10 Dec 2019 Location: limerick Posts: 18 ![]() ![]() |
i think it needs new ones as it rolls like a boat and it hits the bump stops with the slightest bump, on a speed hump the rear lifts really high , thank you for your replies and taking the time to reply ,, sean |
Seams you are the unlucky one then sir |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
I replaced my rears with Bilsteins. I felt safe using Bilsteins because their firmness is ecu-controlled. I had Bilstens on a D2 and found them excessively firm but they're fine on the L322.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
Replaced a few over the past while
The bilstein ones are nearly as much as the LR ones. There is nothing that can't be fixed with a hammer😜😜
thank you for your replies and help . i priced main dealer and was quoted nearly 1000 euro per unit. bilstein prices were about 650 euro for both , i ended up buying the shock absorbers from aerosus in germany suitable for variable dampening costing 450 euro for both.. |
LRDirect had he LR ones at 350 per unit, but 450 for both seems decent, let us know how you get on with them |
Aerosus shock absorbers fitted. Fantastic difference to the driving of the Range Rover . Beautiful handling on all types of roads , |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
Might get some for mine. How many miles on yours? 1995 4.6 v8, green/tan (long gone)
160000 miles -200000 km |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
160 000 mi - 257 000 km 2012 TDV8 Black Edition
