Home > Maintenance & Mods (L322) > Second Battery
Page 2 of 3 <123>
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
It's still p@ssing down here ya knows!! Thumbs Up
Anyhow, here's the pics was promised. looks like a very simple installation to me.
1. A live fitted into the rear fuse box. (pics 1 and 4)
2. A neutral earthed onto the rear panel. (pic 5)
3. Simple clamp-on terminal leads. (pic 2)
What could possibly go wrong! ?? Whistle Shocked Laughing
Post #550707 17th Apr 2020 5:25pm
GraemeS
I fitted an AGM battery. I don't like battery acid.
Don't permanently connect the 2 batteries because if someone disconnects the front one when the vehicle is involved in a bad accident then the rear one will still be connected which could result in a fire.
Post #550733 17th Apr 2020 8:41pm
Dizzy Dee
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
I'm looking at doing this as I am currently running a 12v hand wash in the boot of the FFRR.
I will be using one of these
SPLIT-CHARGE-RELAY-12V-140A-140-AMP-VOLTAGE-SENSITIVE
Battery type to be confirmed.
Will update when I have done it.
Post #550734 17th Apr 2020 8:47pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
Re: Second Battery
[quote="zarnd"]I have been looking into this and seen a couple of threads on here about people who have done these and looking for some feedback. This is not something I could make myself so looking at available kits to buy and then fit myself.
Have found two and was looking for some feedback or if anyone has used either?
https://www.luxurylandroverupgrades.com/pr...attery-kit
Or
http://www.traxide.com.au/diy-dual-battery...t90-s.html
I want to be able to run something in the boot from the 12v socket and not worry about the car not starting again if I tan a fridge for example and left the car with it running. Also would like to be able to leave the ignition on to be able to watch tv/dvd whilst stationary without worrying about not starting again
Cheers[/quote
A very good option;
Post #550739 17th Apr 2020 10:18pm
Dolphinboy
Thats the way to do it!! (with apologies to Punch and Judy)
Great vid and installation. that's about £150 sterling for the whole kit right? plus the battery.
Post #550742 17th Apr 2020 11:31pm
RR P38
Join up with https://www.aulro.com/afvb/ Australian Land Rover Owners.................
I think you will get it cheaper, there is an online shop on the site
Post #550743 18th Apr 2020 1:28am
Maccaa
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
[quote="Dolphinboy"]It's still p@ssing down here ya knows!! Thumbs Up
Thanks Dolphinboy pics very much appreciated especially with the weather so bad yesterday down our "neck of the woods"
Maccaa Current FF Westminster 4.4 V8
Post #550761 18th Apr 2020 9:30am
Dolphinboy
Thumbs Up Thumbs Up
Post #550772 18th Apr 2020 11:02am
Bluegreygreen Rangie 2
Australia
Im curious what your hand wash is as you see the funny thing is i have a water tank fited where people fit this second battery... it gravity feeds to the outside of the car which is for washing my hands
Dave 2010 3.6TDV8 Autobiography
Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #550816 18th Apr 2020 2:56pm
Dizzy Dee
Hi Dave,
Handwash is nothing special, and not fitted permanently. It is made by Teal and heats up the water as you drive, but don't want to take the risk with flattening the battery. (I can look stupid on my own, don't need the RR to assist)
It holds about 3 L of water and the waste drains into the bowl and can be stored until it is emptied.
Post #550997 19th Apr 2020 6:47pm
Australia
I see... Great idea. The way things are going we will all have to carry something like this soon Razz
I've seen something similar in some work Vans in Australia I'm sure
GAP Diagnostics
Post #551014 19th Apr 2020 7:19pm
Dizzy Dee
Yes they are used in work vans quite alot, I went for this one as it free stands or wall mounts, and holds the waste water.
I have been looking for a while as some building sites don't always have good washing facilities, Plus i normally only remember when I get back to the car.
I'm also interested in the setup in your ffrr. sounds a bit more fitted than mine.
Post #551019 19th Apr 2020 7:42pm
Brian Considine
All the bin trucks I've driven have had permanent ones installed - they run off the engine coolant.
Most trucks used for waste also have them. 2003 Range Rover Vogue TD6
Post #551032 19th Apr 2020 8:52pm
Australia
Hi Dizzy, Yes mine is a permenant fitment... I will do a to a write up and pics of it very soon as im sure some one will want to do the same, It holds ten liters of water and allows me to wash my hands properly after getting greasy etc however keep in mind it is not heated which might be of importance more so in colder climates where you are perhaps
GAP Diagnostics
Post #551121 20th Apr 2020 3:20pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I do not like the fact that the loom that runs across the bottom of the reccess is now unprotected and very vunrable to rubbing and damage. On my similar instal I lifted the loom up and out and managed to re route it over the rear fuse box out of harms way. I would also strongly recommend a fuse between the second battery and the fusebox 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #551331 22nd Apr 2020 1:04am
Page 2 of 3 <123>
