Home > Technical (L322) > 2011 L322 thinks trailer is attached? Green light flashing |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
I would start by looking for any signs of moisture or corrosion in the sockets.
1st Apr 2020 7:13am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
I concur with Mike. I bet if you shine a torch in there you'll see some nice green corrosion on one of the terminals. Electrical spray contact cleaner should do it??? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
1st Apr 2020 7:47am |
MarshallW11 Member Since: 24 Jan 2019 Location: Ottawa Posts: 18 |
Hi there,
3rd Apr 2020 2:19pm |
jjjjs5518 Member Since: 17 Sep 2018 Location: london Posts: 26 |
Hi guys,
13th Apr 2020 11:41pm |
Sorry,
16th Apr 2020 5:25pm |
Yes I thought they would be the obvious culprit if fitted! Any other ideas? Maybe something is shorting in the fuse box? |
16th Apr 2020 11:35pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
The external harness connects to a socket in the back lower edge of the spare wheel well. A blank plug should be fitted but if missing then moisture could get to the exposed terminals. |
16th Apr 2020 11:44pm |
That would be it! There are some wires with a broken connector - pic attached.
17th Apr 2020 9:05am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
Ooops, how did that happen !!?? Current: 2011 FFRR Vogue SE 4.4 TDV8
17th Apr 2020 9:18am |
No idea - I’ve not owned the car long! I assume when the spare was put in it broke the plastic connector!
17th Apr 2020 1:09pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Tape up any leads still properly attached to the plug, then isolate and tape up every other stray wire... you can probably buy a new plug from the dealers if you want to use it... Pete
17th Apr 2020 5:37pm |
Maybe it needs the blocking plug because i have taped up all the wires and still got the same problem.. hmm |
17th Apr 2020 6:35pm |
Yep, it's a Range Rover, anything is possible, it may need a cap, it may need the ECU resetting or it could be damage to the loom just under the black strapping, did whatever damaged the plug squash the loom and short the wires...!! Pete
17th Apr 2020 7:11pm |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
I suspect a previous owner has removed the towing kit, and that broken connector and set of wires only goes under the bumper to where the electrics would have been so isn't connected to anything. However it maybe that the towing electric module is still connected to the car in the right hand panel as per Marshall's earlier post/picture and that broken socket would have connected to a loom coming out of that - and that is probably where the problem is. See if there is another set of similiar wires coming out of the right hand panel. Current Fleet:-
17th Apr 2020 7:18pm |
