Home > Technical (L322) > 2011 L322 thinks trailer is attached? Green light flashing
jjjjs5518
2011 Range Rover Vogue SE TDV8 Santorini Black
Hi all
My 2011 4.4 tdv8 flashes the green trailer light on the dash when indicating right. Just wondering if anyone knows why this is? Also this causes the blind spot monitor not to work as the car thinks a trailer is attached.
Any ideas on how to sort this?
Thanks in advance!
Post #549031 31st Mar 2020 11:51pm
Baltic Blue
I would start by looking for any signs of moisture or corrosion in the sockets.
Post #549041 1st Apr 2020 7:13am
DrRob
I concur with Mike. I bet if you shine a torch in there you'll see some nice green corrosion on one of the terminals. Electrical spray contact cleaner should do it??? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #549044 1st Apr 2020 7:47am
MarshallW11
Canada 2003 Range Rover Vogue Td6 Giverny Green
Hi there,
I'm not sure if this can help or if it applies to your RR. On my 2003, I had the same problem. It began after I had new trailer wiring installed. I remedied it by unplugging the tow module from the trunk when not towing, and only plugging it back in when I was towing something. I've been doing that for about a year now with no further issues. Maybe that can help you temporarily until you have time to properly investigate the problem.
Post #549249 3rd Apr 2020 2:19pm
jjjjs5518
Hi guys,
Apologies for the late reply! Very rude!
Just to confirm Baltic Blue, what sockets are you referring to? My car does not appear to have the towing pack as cant find a tow bar nor any electrics relating to that underneath the car.
Best
Post #550259 13th Apr 2020 11:41pm
Baltic Blue
Sorry,
I was referring to the 2 sockets associated with the tow pack.
One with a black cap and one with a white cap., but if they are not fitted on yours, then obviously not the problem.
Post #550532 16th Apr 2020 5:25pm
jjjjs5518
Yes I thought they would be the obvious culprit if fitted! Any other ideas? Maybe something is shorting in the fuse box?
Post #550583 16th Apr 2020 11:35pm
GraemeS
The external harness connects to a socket in the back lower edge of the spare wheel well. A blank plug should be fitted but if missing then moisture could get to the exposed terminals.
Post #550584 16th Apr 2020 11:44pm
jjjjs5518
That would be it! There are some wires with a broken connector - pic attached.
Post #550606 17th Apr 2020 9:05am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Ooops, how did that happen !!?? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #550607 17th Apr 2020 9:18am
jjjjs5518
No idea - I’ve not owned the car long! I assume when the spare was put in it broke the plastic connector!
Any ideas for a safe fix? The plastic block connector has broken in 2 pieces
Post #550668 17th Apr 2020 1:09pm
Tape up any leads still properly attached to the plug, then isolate and tape up every other stray wire... you can probably buy a new plug from the dealers if you want to use it... Pete
Post #550711 17th Apr 2020 5:37pm
jjjjs5518
Maybe it needs the blocking plug because i have taped up all the wires and still got the same problem.. hmm
Post #550718 17th Apr 2020 6:35pm
Yep, it's a Range Rover, anything is possible, it may need a cap, it may need the ECU resetting or it could be damage to the loom just under the black strapping, did whatever damaged the plug squash the loom and short the wires...!! Pete
Post #550724 17th Apr 2020 7:11pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
I suspect a previous owner has removed the towing kit, and that broken connector and set of wires only goes under the bumper to where the electrics would have been so isn't connected to anything. However it maybe that the towing electric module is still connected to the car in the right hand panel as per Marshall's earlier post/picture and that broken socket would have connected to a loom coming out of that - and that is probably where the problem is. See if there is another set of similiar wires coming out of the right hand panel. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #550725 17th Apr 2020 7:18pm
