Home > Technical (L322) > P0486 - Exhaust Gas Recirculation Sensor B Circuit |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Restricted Performance is nearly always a boost leak, however that code is not one I've seen come up.
14th Apr 2020 6:13am |
jjjjs5518 Member Since: 17 Sep 2018 Location: london Posts: 26 |
Hi there,
14th Apr 2020 7:09pm |
They might have bodged it, especially hearing the DPF is removed.
14th Apr 2020 7:21pm |
Well the DPF was actually removed prior to me purchasing the car - I was only aware of this when I was told the car needed the necessary programming.
14th Apr 2020 7:27pm |
Do you think it is ok to continue to drive the car despite all this? |
15th Apr 2020 10:30am |
I'd have a look and see if sensor B has been unplugged.
15th Apr 2020 10:59am |
Thanks for the advice - will carry on in that case!
15th Apr 2020 7:50pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3780 |
Has it had an MOT since the DPF was removed ?
15th Apr 2020 8:23pm |
Its obviously been done very well - the garage didn't realise at first!
16th Apr 2020 12:05am |
16th Apr 2020 2:44pm |
Is it possible that it is an import ?
16th Apr 2020 3:11pm |
Hmm i think it looks a little beyond me to remove that 'doughnut' manifold! Worried about making things worse than better haha |
16th Apr 2020 5:10pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
jjjjs5518,
5th May 2020 10:10am |
