Home > Technical (L322) > P0486 - Exhaust Gas Recirculation Sensor B Circuit
Davlyn
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Was there ever a conclusion to this problem?
Post #624182 19th Feb 2022 4:52pm
paulwlincs
I had exactly the same error code , mine turned out to be the throttle body which when replaced cured the problem.
I know it's unrelated to egr circuit b but a Duckworths tech spotted a slightly high throttle body voltage so I had it changed.
I was going round in circles , anyway hope you get there . 2011 tdv8 4.4 vogue Santorini black
Post #624197 19th Feb 2022 7:52pm
Stanley
I had the same, ended up having the sensor changed and the throttle body. 2011 TDV8 Vogue
1996 4.6 HSE
Post #624217 20th Feb 2022 9:30am
