Home > Technical (L405) > deployable side steps and lifting
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
Okay to use those jack points to lift the entire car? I'm having a lift installed tomorrow. Also is there a specific puck to be used on those points?
thanks
Post #550370 15th Apr 2020 12:07am
Yes sir... I have a 2 poster ramp & deployable steps and it lifts the car just fine... Thumbs Up
Post #550372 15th Apr 2020 12:22am
brad s1
Thanks as usual craig... Are you using any specific puck on the contact points?
Post #550399 15th Apr 2020 1:10pm
Definitely genuine steps ?
We had someone on here a while ago & turned out they had after market plastic steps.....
Post #550400 15th Apr 2020 1:22pm
JohnGalt11
United States 2009 Range Rover Supercharged Supercharged Santorini Black
I had the deployable steps on my Ford F150, and they were by far the most useful steps I've ever had on a vehicle. Until they were about 5 years old and they stopped wanting to go up in the winter. There were no grease fittings on them and using surface applications of WD-40 was only temporarily useful. Getting them apart to clean and lubricate them was a giant pain as they were clearly never made to be serviced. They got to the point that it was just easier to turn them off and not use them. So, unless you're prepared to disassemble them and clean them every couple of years, stay away. Note: We get frequent snow storms where I live and it gets down to -20 to -30C pretty regularly during the winter months. More mild climates may not have the issues I had. 2009 L322 SC
Post #550401 15th Apr 2020 1:43pm
brad s1
Yeah they're genuine.
I lock them deployed and marine grease them to service, so far so good... I could see wd40 doing more harm than good given it isn't a lubricant. I didn't personally fit them, the car is autobiography and just came with them. If it were my choice I'd have gone with standard steps.
Post #550406 15th Apr 2020 3:52pm
/\ Less to go wrong I guess.
An important distinction is that they are not 'factory' - even if spec'd on a new car, they are dealer fitted - which only really matters when it comes to warranty - they have their own and are not covered as part of the car - therefore cannot be extended.
As they are not on the build sheet - I guess they should also be declared as a modification - I hadn't thought about that before Confused
I need this house arrest to come to an end so I have better things to do than interfere on threads like this Whistle
Post #550408 15th Apr 2020 5:12pm
brad s1
To anyone else as expected craig is on point as usual...
1.) get in the car, hold down button press ignition, steps will lock away
2.) drive up to the 2 posts until they're parallel with the front seat cushion
2.) place arms on jack points or steps
Tested it out by putting the summer turbines on
[img]https://i.imgur.com/eD090tA.jpg?1[/img]
[img]https://i.imgur.com/vprhumu.jpg?1[/img]
New questions... turbines aren't supposed to be directional are they? As on one side the spokes sweep back and on the other they're rotating forward. Seems like for the type of money they cost they should be directional.
Post #550501 16th Apr 2020 1:53pm
Thumbs Up Thumbs Up Thumbs Up
Post #550503 16th Apr 2020 2:02pm
I thought about a wind up but someone would spoil it.....
No they are not directional, so no need for 2 spare wheels.
Post #550511 16th Apr 2020 3:24pm
its a silly design... ... - .- -.
Post #550522 16th Apr 2020 4:18pm
Weegie
Though it's difficult to see both sides at the same time. Whistle John
GAP iiD BT-Sold
Post #550525 16th Apr 2020 4:32pm
But somehow attractive - at least to me - I think it's the best looking 22" wheel
The spokes aren't the same either - alternate ones are different - but somehow it works..... Thumbs Up
Post #550533 16th Apr 2020 6:36pm
I can't have them on my FF as it messes with my ocd having the turbine effect going the wrong way on one side of the car! Whistle Whistle Whistle Rolling Eyes
Post #550560 16th Apr 2020 10:13pm
brad s1
I never noticed and when I went to refit them was certain the dealer screwed me... selling me two sets for the same side. Now that I noticed it is going to bother me. Laughing
Post #550568 16th Apr 2020 10:38pm
