![]() | Home > Technical (L322) > Battery Borked? Seeking Opinions |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Battery could be the cause. What is the voltage with the ignition off and the car ‘asleep’? |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
@ur20v - Fluctuates between 11.2/11.3/11.4 volts. |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Similar issue I have with mine , run ok for approx 20 miles then all kinds of errors. Recharge overnight and same next time used. Eventually the battery light flashed and then stayed on pointing to the alternator being at fault. |
If your battery is only showing ~11 volts after a being charged for 6 hrs you either have a big drain or the battery is possibly at fault.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 ![]() ![]() ![]() |
You need a new battery |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 895 ![]() ![]() |
Battery.....I'm in the same boat as you the cold nights early at the start of the year killed it iv got a trickle charger on it for now just deciding which is the biggest battery I can fit to my 4.4 m62 engine |
Thanks all. Time for a new battery methinks. |
