Home > Technical (L322) > Battery Borked? Seeking Opinions |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Battery could be the cause. What is the voltage with the ignition off and the car ‘asleep’? |
10th Apr 2020 2:41pm |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 |
@ur20v - Fluctuates between 11.2/11.3/11.4 volts. |
10th Apr 2020 2:48pm |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Similar issue I have with mine , run ok for approx 20 miles then all kinds of errors. Recharge overnight and same next time used. Eventually the battery light flashed and then stayed on pointing to the alternator being at fault. |
10th Apr 2020 4:01pm |
If your battery is only showing ~11 volts after a being charged for 6 hrs you either have a big drain or the battery is possibly at fault.
10th Apr 2020 4:15pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
You need a new battery |
10th Apr 2020 4:26pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 895 |
Battery.....I'm in the same boat as you the cold nights early at the start of the year killed it iv got a trickle charger on it for now just deciding which is the biggest battery I can fit to my 4.4 m62 engine |
10th Apr 2020 5:47pm |
Thanks all. Time for a new battery methinks. |
10th Apr 2020 9:20pm |
