![]() | Home > Technical (L322) > Removing Front Interior Lights/Sunglasses Panel?? |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
There are to screws when you open the sunglasses holder. |
TJRL Member Since: 07 Sep 2019 Location: Reading Posts: 198 ![]() ![]() ![]() |
Tinman you are a star. |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Get some cable fishing rods, rod front the front to the back in the headlining -- you should be able to get enough of the headlining down at the front by removing the grab handle above the door -- you can get the headlining down at the back and almost get your whole arm in the roof space -- should be able to feed cables through into the tailgate through the rubber cable runs |
If You check out the wiki and look at the deployable steps DIY version that will help you? |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 595 ![]() ![]() ![]() |
I installed a front and rear dash cam on Sunday, i was surprised how easy it was.
Many thanks all for your tips and advice.
Sorry you did mention that you couldn't remove the A post trim...
Success!! |
