Home > Technical (L322) > Whop whop noise?
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Whop whop noise?
I went out fir the first time in a week yesterday and noticed that Silvia has developed a whop whop noise similar to the noise of a distant helicopter.
At first I thought that it was the road surface, but it continued on roads I had previously driven and not had the noise. I then checked the tyres and tyre pressures which were all good.
I have checked for loose trim, wheel bolt tightness and am now scratching my head. The noise appears at around 40 mph and is there constantly.
Any ideas???
Jim
Post #549321 4th Apr 2020 8:53am
bruce
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Distant helicopter perhaps. If you are not part of the solution you are part of the problem!!
Post #549329 4th Apr 2020 9:41am
jim4244
Bruce, read your own signature 👍
Jim
Post #549333 4th Apr 2020 9:56am
A calliper stuck/sticking! Drive it a while then put your hand on each wheel and see if one is much hotter than the others? 👍
Post #549334 4th Apr 2020 9:57am
jim4244
Thanks Cam 👍
Post #549339 4th Apr 2020 10:14am
jim4244
Took the old girl out for a 5 mile drive (the rangie not my wife) and then measured the temperature of the brake callipers.
FNS = 20C, FOS = 19C, RNS = 19C, ROS = 54C
I have been meaning to change the handbrake shoes For a couple of months so also stripped down, cleaned and lubricated the ROS brake calliper.
Silvia is still on axel stands so when I have put her back together I’ll let you know if Cam had hit the nail on the head.
Jim
Post #549375 4th Apr 2020 5:00pm
Post #549411 4th Apr 2020 10:13pm
Make sure to take the Caliper carrier off the car and thoroughly clean with a wire brush/grinder brush wheel if possible. They rust which makes the pass stick in them. Sometimes it’s the pads sticking in the carrier rather than the Caliper itself. Worth trying as it’s a free fix if it works.
If not it’s a rebuilt calliper from a motor factor, normally
On exchange so they aren’t too much money. There is nothing that can't be fixed with a hammer😜😜
Post #549419 5th Apr 2020 12:30am
jim4244
I removed the carrier and calliper and cleaned as you suggested.
They are extremely corroded, which makes me think that they are the originals.
Jim
Post #549426 5th Apr 2020 8:16am
When you refit the pads make sure the just pop in nicely. You shouldn’t have to force them in at all. There is nothing that can't be fixed with a hammer😜😜
Post #549427 5th Apr 2020 8:17am
jim4244
All back together now. What a #£&*@+ of a job it is to replace the handbrake shoes!
Been out for a drive and the whop whop noise has gone and the temperatures of all 4 brake callipers in the mid 20C range.
Handbrake also holds the car now as well so a productive 2 days.
Jim
Post #549457 5th Apr 2020 1:58pm
Glad its sorted Jim... Thumbs Up
Post #549469 5th Apr 2020 4:50pm
coolio.
keep a watch on the temps for a week or so just in case its lulling you into a false sense of security. Laughing There is nothing that can't be fixed with a hammer😜😜
Post #549478 5th Apr 2020 5:27pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Nicely done Thumbs Up (and yeah, handbrake shoes- royal PITA - did mine 3 weeks ago so I know exactly what you mean.)
Post #549489 5th Apr 2020 7:08pm
jim4244
Stu, how many times did you swear when trying to engage the top spring back in both shoes? 😂
Jim
Post #549492 5th Apr 2020 7:35pm
