Home > Maintenance & Mods (L405) > Battery Conditioner |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
29th Mar 2020 10:08am |
Ocean53 Member Since: 14 Feb 2018 Location: Chichester Posts: 75 |
What’s the positive post under the bonnet?
30th Mar 2020 1:11pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
Yes - the positive post under a cover & the negative post next to it are the ones to use. |
30th Mar 2020 1:14pm |
Thank you all.
30th Mar 2020 2:25pm |
Lyonhead Member Since: 05 Aug 2017 Location: Cardiff Posts: 349 |
Hi Alistair, ordered on the 28th and delivered today (30th). All fitted. Thanks for the info. 19MY SVA-Dynamic Spectral Chromoflair Blue but colour not available in profile 2016 RRS SVR Estoril Blue - Gone 2010 RRS 5.0 Supercharged Navara Bronze - Gone 2008 RRS 4.2 Supercharged Black - Gone 2006 RRS 2.7 Diesel Rimini Red- Gone |
30th Mar 2020 9:34pm |
SCL Member Since: 10 Jul 2017 Location: West Midlands Posts: 50 |
I am looking to buy a battery conditioner after having a flat battery earlier in the week as a result of not using the car.
3rd Apr 2020 7:24am |
MXS 5 seems fine for me - I'm sure there's a benefit to the bigger & more expensive ones.
3rd Apr 2020 7:35am |
3rd Apr 2020 8:14am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7799 |
I’ve got the 7. No issues for many years. It also has an AGM setting, which is what we need.
3rd Apr 2020 8:17am |
Good point - I can't remember the size of the battery - I think it's probably close to 110Ah though so towards the top end of spec for a full charge but fine for maintenance
3rd Apr 2020 8:43am |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
If running long extension leads I would spec a higher output unit than the 5amp model, you get a voltage drop with long cables also the very large batteries used in ff’s have a high internal resistance and will need a very high load when flat to charge, again a 10 or 15 amp unit will be needed to get you going in a reasonable time, a 5 amp unit might take 48hrs plus to charge a fully flat ff.
3rd Apr 2020 8:51am |
Ian58 Member Since: 30 Mar 2020 Location: Kent Posts: 9 |
Just purchased a CTEK MXS 5.0 from Partshop247 (eBay) ordered Tuesday, arrived Wednesday. I removed the spare wheel to connect straight across the battery, I can't believe the epic that was, or the weight of the wheel once it was out!!!....won't be doing that again to charge the vehicle. I have now checked the posts under the bonnet and the croc clips will connect laying flat so the bonnet can be closed ok. I took the cable out through the scuttle area with no problems of cable trapping. There is a CTEK Accessory extension cable available (56-304) that is 2.5m long that I think will make the job easier so will be ordering one.
3rd Apr 2020 8:52am |
Many thanks mjdronfield
3rd Apr 2020 9:27am |
ur20v and Ian58 many thanks for your valuable input. Much appreciated.
3rd Apr 2020 9:34am |
