Home > Maintenance & Mods (L322) > White Smoke Cloud L322 4.4. TV8 |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3182 |
if you are getting limp mode, a recurring DPF amber and red and full DPF, then I would suggest you have an air leak, possible any of the 4 pipes to the plenum on top of the engine, or a cracked inlet manifold (passenger or driver side).
28th Mar 2020 5:37pm |
maxg67 Member Since: 10 Jan 2020 Location: Verbania Posts: 12 |
Thank you Dolphinboy,
28th Mar 2020 7:57pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Does sound similar to another white smoke report here:
28th Mar 2020 8:21pm |
Also welcome!
28th Mar 2020 8:28pm |
Just re-reading your issue, an air-system leak it could have caused the smoke, given you found one loose hose this could have been the case. Maybe. I would monitor it.
28th Mar 2020 8:44pm |
Thanks GGDR,
28th Mar 2020 8:57pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 901 |
The colour of the smoke indicates the type of fault you may have, white smoke is air in the fuel. Hopefully you have found the problem with the loose hose |
28th Mar 2020 9:33pm |
