Home > Maintenance & Mods (L405) > locking wheel nut |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35332 |
in the boot under the load cover...on the left under a flap... ... - .- -.
28th Mar 2020 11:21am |
Blackbird Member Since: 22 Feb 2020 Location: York Posts: 26 |
Stan you are a superstar. Thank you very much |
28th Mar 2020 12:38pm |
i'll only be a superstar if its actually there and you find it ... - .- -.
28th Mar 2020 1:06pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8531 |
Took me a while!!
28th Mar 2020 2:02pm |
It was there Stan but by hell the wheels are heavy to lift back on. |
28th Mar 2020 4:04pm |
thats a result. and yes they are heavy ... - .- -.
28th Mar 2020 4:07pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1425 |
You need a set of wheel fitting guides. See here...... https://www.fullfatrr.com/forum/topic43537.html 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
28th Mar 2020 4:52pm |
Thanks Rob I will get some guides, they must be a lot easier than trying to lift on. |
29th Mar 2020 8:50am |
there is an easier way to lift the wheel onto the studs...
29th Mar 2020 8:56am |
Thanks Stan, it sounds like I need practice to get the technique right. |
29th Mar 2020 11:14am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Me: Don't jack it more than needed, line up the studs then a foot under each side.
29th Mar 2020 11:42am |
Thanks Greg will try. I have a trolley jack but only used the one provided with car yesterday. If using a trolley jack where is the best place the jack on the RR. Jim. |
29th Mar 2020 1:06pm |
