Home > Maintenance & Mods (L405) > Battery Conditioner
Page 1 of 5 12345>
Ocean53
United Kingdom 2018 Range Rover Vogue SDV6 Corris Grey
Battery Conditioner
Hi
I’ve looked in the handbook of my 2018 Vogue and it doesn’t seem to want any Battery maintenance.
On my other car I can attach a charger into the cigarette socket to maintain condition.
As I’m not using the RR at the moment, does anybody know if you can do the same, either on consol socket or load space socket? And is it advisable?
Post #548534 28th Mar 2020 12:18pm
Phil.
I think you’ll find that the 12v sockets are only active when the ignition is on, so you can’t use them for battery charging.
I charge directly to the main battery in the boot under the spare wheel. You will need a battery conditioner rather than a charger e.g. accumate or optimate. I connected one of these leads to the battery to make connecting the conditioner easy:
https://www.optimate.co.uk/products/o11-weatherproof-eyelet
If you don’t have a power source available (like when I park mine at the airport for a month) I’ve connected one of the Optimate Solar Chargers and it seems to work well keeping the battery topped up. Because we’re not using the RR much at the moment I’ve connected the solar panel up on the drive and stuck it in the front window. It’s just easier then running a cable from the garage.
https://www.optimate.co.uk/products/optimate-solar
There are past threads on this subject if you run a search. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #548542 28th Mar 2020 12:59pm
CS
If you have tow electrics you can buy an adaptor through this site's Shop which plugs into the tow electrics socket. There are different versions depending on which charger you want to use. I've just ordered one.
Older 322s could be charged via cigarette lighter socket as the sockets remained live even though the car was locked. Only Range Rovers since 1988
Post #548547 28th Mar 2020 2:04pm
you could do this,
https://www.rrsport.co.uk/forum/topic55319.html ... - .- -.
Post #548548 28th Mar 2020 2:04pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Sort of hi jacking this thread. My car hasn’t moved for two weeks nor will it for the foreseeable. My worry is that the battery will drain and when things get back to normal I won’t be able to start the car. I don’t have off street parking, so I can’t plug in a trickle charger - not that I have one. I’d really appreciate any suggestions or products I could source from the internet.
Thanks
Andy
Post #548553 28th Mar 2020 3:59pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I'd start it and stay in the car once in a while. Even ten minutes should do the trick. It's not as though there's much vehicle pollution right now
Post #548554 28th Mar 2020 4:18pm
Phil.
Andy, I described a solar solution above that will work anywhere. I’ve used it for a month last summer while mine was parked at the airport and my RR started fine. MY23 D350 HSE
Post #548556 28th Mar 2020 4:21pm
A large solar panel on the back shelf Thumbs Up
Post #548557 28th Mar 2020 4:22pm
Phil.
Works better in the front if you have blacked out rear glass. MY23 D350 HSE
Post #548559 28th Mar 2020 4:28pm
I've just ordered myself another CTEK - I left mine in France
Post #548577 28th Mar 2020 5:58pm
Ocean53
To plug in where?
Post #548586 28th Mar 2020 6:41pm
TomV8
United Kingdom 2004 Range Rover Vogue 4.4 V8 Bonatti Grey
Another vote for the towing socket adapter from the forum shop. It’s a brilliant bit of kit if you have towing electrics.
I use mine with a CTEK CT5 Time to Go conditioner and it all works well. By coincidence, I plugged it all in today, given that my Range Rover is now in dry dock until we can do unnecessary travel again. 2004 L322 4.4 V8 Vogue Bonatti Grey
(205,500 miles and counting.......)
Post #548588 28th Mar 2020 6:52pm
The charger comes with croc clips & a hard wire option.
I connected mine up to the charging posts under the bonnet (along with an anderson connector) - The CTEK socket is at the bottom of the picture and the charger cable just plugs in there.
I have a deployable tow ball - so getting to the electrics means activating it - which is more hassle than opening the bonnet.....
Post #548590 28th Mar 2020 7:04pm
Ocean53
Thanks
Amazon no delivery before 25/4
Post #548595 28th Mar 2020 7:17pm
Andy S
Thanks for the suggestions, but please bear with me here. I am not technically minded at all and having looked at various solar chargers on the web, it seems that you need to attach the cables to the battery terminals. That makes sense, but surely that means I have to leave the bonnet loose and the engine bay accessible to any scrote that walks past the car, which is parked on the street. In addition, wouldn’t the cable need to run through the door, so when the door is closed the cable would be pinched and have reduced functionality?
As I said, I’m not technically minded and probably over thinking this, but would really appreciate a noddy guide.
Thanks
Andy
Post #548596 28th Mar 2020 7:17pm
Page 1 of 5 12345>
