![]() | Home > Maintenance & Mods (L322) > Engine Cutting Out Intermittently - 2012 4.4 TDV8 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Excellent result.
roel2018 Member Since: 01 Oct 2018 Location: Aalter Posts: 39 ![]() ![]() ![]() |
This could also solve my problem |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
I’ve had the best part of 5 years smooth running since replacing the Crankshaft Position Sensor.
neil3728 Member Since: 24 Feb 2020 Location: Howden Posts: 51 ![]() ![]() ![]() |
Is it an easy fix, Mrs is complaining of a small loss of power for a second while driving today. 2011 Vogue 4.4 TDV8
In 3 weeks I have the MOT so I asked the LR workshop. Part number LR049872 is replaced by LR126062. They asked € 308 (or 270 pounds) for labour so I think it is a job for about 3 hours. They also check if my one has update LTB00454v2 is done. 2017 Range Rover 4.4 SDV8 Autobiography DPF - 100k miles - Dutch |
I'm not sure about fitting. I had the garage fit it. ------------------------------------- MY 2012 4.4 TDV8 |
Today I was at the local LR workshop. My RR was not updated with LTB00454v2 so they run a diagnostic test. No failure was recognizable/logged, no failures for the crankshaft position sensor so that saves me a little €500 (446 pounds). The update cost me € 64 (57 pounds) so hopefully my problem is solved...
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Can anyone advise the suggested time to update the PCM as presumably shown on LTB00454 please? My L322 is booked to have the update done tomorrow morning and I'd like to have some idea of the time. It is also booked to have the BCM updated and as there are several other modules that aren't at the latest level I'll be trying to get them all updated, but I expect the PCM to take the longest by a fair margin.
Does the update have to be done at a Land Rover garage, Mine us rather useless recently.
Gap has advised that their tool can't do the update.
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
Slightly off topic but I am getting the software update for the gearbox done next week as above (LTB00454v2)
Ok. Last year my fattie was updated with LTB00454v2 in March 2020. But yesterday it happens again twice! So, i think i need a new CPS Crank Positioning Sensor.... 2017 Range Rover 4.4 SDV8 Autobiography DPF - 100k miles - Dutch |
The sensor has been superseded twice since our vehicles were built so maybe improved. |
Which one is the latest for the TDV8 4.4 diesel? LR126062? Or the LR049872? 2017 Range Rover 4.4 SDV8 Autobiography DPF - 100k miles - Dutch |
