Home > Maintenance & Mods (L322) > 05 L322 REAR SUSPENSION GOING DOWN |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 |
you've got a leak somewhere. If its worse when its the coldest days that's a clear sign of a leak most likely in the air bag. Can be tricky trying to find the leak. When the air bag blows you'll know b/c it will throw a suspension fault and put you on bump stops 2014 FF Autobiography 5.0 SC
24th Feb 2020 8:31pm |
deltic Member Since: 18 Jun 2018 Location: dublin Posts: 57 |
No faults shown dont think its the bags had a good luck |
10th Mar 2020 6:05pm |
10th Mar 2020 6:06pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 |
As above, you won’t get a fault till it blows.....then it’s, well, obvious, so no fault message really needed.
10th Mar 2020 6:13pm |
Always Member Since: 04 Nov 2013 Location: Yorkshire Posts: 54 |
Sounds like a leak to me. Just because you can't see it doesn't mean it isn't there.
10th Mar 2020 7:09pm |
Cheers for that did spray l
12th Mar 2020 8:03pm |
Look for leaks at the junction boxes too where the lines hook up. 2014 FF Autobiography 5.0 SC
13th Mar 2020 3:45am |
99% certain you've got a leak somewhere. If you had a tyre that was slowly going flat over a few days what would you conclude? Same logic. How often can you 'see' a slow puncture? If you want to eliminate 'electronic trickery', just park it up and disconnect the battery, then leave it for a few days. If it still sinks you've got a leak. If it doesn't, I'm wrong. |
13th Mar 2020 8:51am |
