Home > Maintenance & Mods (L322) > Diesel heater in 2003 4.4 v8
Ghostx666
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Morning all,
My l322 doesn't have the FBH and it's something that I wish it did have.
I have been thinking about installing a diesel heater in the compartment for the FBH with an aux diesel tank also, I managed to work out where everything goes apart from the actual heating ducts.
I want to get the hot air to come out of the existing vents in the l322 but struggling to find the best way to tap into existing duct work, any got any info or ideas for this?
Regards
Greg Greg R
Range Rover l322 4.4 V8 Vogue 2003 (current)
Land Rover Discovery 2 TD5 GS 2000 (current)
Land Rover Discovery 1 3.9 V8 Trayback 1994 (current)
Land Rover Discovery 1 300tdi 1997 (Sold 2018)
Post #546252 7th Mar 2020 2:17am
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
On the diesel the fbh heats the water in the cooling system and has its own circ pump so runs through the normal heater system and uses the fan on slow to warm the car if that helps, think I have seen somewhere that even some petrol models had the fbh.
Post #546365 7th Mar 2020 10:39pm
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
you can get petrol FBH 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #546481 8th Mar 2020 8:50pm
Dolphinboy
Yes you can. I have one on my 2004. Factory fitted tho!
Post #546484 8th Mar 2020 9:23pm
Ghostx666
I think everyone is getting mixed up, I am looking to install something aftermarket rather than retro ft an original Greg R
Post #546493 9th Mar 2020 1:41am
I wouldn't have thought it was physically possible to get air ducts from a diesel heater into the car to connect with the existing distribution system.
Post #546503 9th Mar 2020 8:23am
Dolphinboy
post removed
Post #546506 9th Mar 2020 8:36am
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I wonder what the part numbers are and how easy to do a retro fit. I hove love it on my SC but had always assumed its was Diesel only.
Post #546507 9th Mar 2020 9:00am
Ghostx666
I have actually found some instructions in the past on how to retrofit an original FBH but it's very very labour intensive and very expensive. Greg R
Post #546509 9th Mar 2020 9:16am
lighthouse
But how cool to have a proper FBH and no additional tank or cutting into vents etc.
Interested now and will see how much the parts are.
Post #546518 9th Mar 2020 10:18am
322BLL
Estonia
There is no factory installed fbh loom on petrol models? Only on the cars ordered with fbh?
Post #546522 9th Mar 2020 10:34am
Thinking about this, if you wish to fit an aftermarket diesel heater why does it have to be connected to the existing system. Surely all you need to do is get the warm air duct(s) into the car in a suitable position, terminate it in a grille(s) and thereby blow warm air into the car. Lot of space underneath the car to run duct(s) to suitable positions.
Post #546528 9th Mar 2020 11:52am
Ghostx666
That's works to be fair, I will have a look see were I could get to ducts into the car. To be fair all it would need is on in each front footwell, warm air rises so footwells would work. Greg R
Post #546570 9th Mar 2020 3:38pm
Footwell area would have been my choice as well Thumbs Up
Does the heater unit also have a return air duct or is it fresh air only?
Post #546601 9th Mar 2020 7:30pm
Ghostx666
Return to unit or fresh air, it comes with an intake duct that can go anywhere. Greg R
Post #546706 10th Mar 2020 6:49pm
