![]() | Home > Maintenance & Mods (L322) > Diesel heater in 2003 4.4 v8 |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
On the diesel the fbh heats the water in the cooling system and has its own circ pump so runs through the normal heater system and uses the fan on slow to warm the car if that helps, think I have seen somewhere that even some petrol models had the fbh. |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 371 ![]() ![]() ![]() |
you can get petrol FBH 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Yes you can. I have one on my 2004. Factory fitted tho! |
Ghostx666 Member Since: 07 Mar 2020 Location: West Midlands Posts: 11 ![]() ![]() ![]() |
I think everyone is getting mixed up, I am looking to install something aftermarket rather than retro ft an original Greg R
I wouldn't have thought it was physically possible to get air ducts from a diesel heater into the car to connect with the existing distribution system. |
post removed |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
I wonder what the part numbers are and how easy to do a retro fit. I hove love it on my SC but had always assumed its was Diesel only. |
I have actually found some instructions in the past on how to retrofit an original FBH but it's very very labour intensive and very expensive. Greg R
But how cool to have a proper FBH and no additional tank or cutting into vents etc.
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 ![]() ![]() |
There is no factory installed fbh loom on petrol models? Only on the cars ordered with fbh? |
Thinking about this, if you wish to fit an aftermarket diesel heater why does it have to be connected to the existing system. Surely all you need to do is get the warm air duct(s) into the car in a suitable position, terminate it in a grille(s) and thereby blow warm air into the car. Lot of space underneath the car to run duct(s) to suitable positions. |
That's works to be fair, I will have a look see were I could get to ducts into the car. To be fair all it would need is on in each front footwell, warm air rises so footwells would work. Greg R
Footwell area would have been my choice as well |
Return to unit or fresh air, it comes with an intake duct that can go anywhere. Greg R
