Home > Technical (L322) > Transfer Box ECU / PDC ECU - Communication Error |
PovertySpec Member Since: 28 Nov 2019 Location: Durham Posts: 35 |
Hi all,
6th Mar 2020 5:10pm |
Was the ecu a straight swap or did it need programmed in? |
7th Mar 2020 11:09am |
Actually, little update to this, had to disconnect the battery whilst I tackled what wiring issues I could, and after reconnecting, both the PDC ECU and Transfer Box ECU are now working, and I've been able to check and clear codes correctly. |
7th Mar 2020 6:48pm |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 222 |
Good, amazing what battery off can do. But just in case, found ecu with same part number had to redone couple of pins in connector then could clear codes no codding in needed. |
7th Mar 2020 9:15pm |
Good to hear no coding is needed, I have a spare just in case, and I may well need it - tried it again today and same error. |
8th Mar 2020 9:30pm |
