![]() | Home > Wheels & Tyres > Tyre width |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 ![]() ![]() |
OEM 275/40/22 and no they should not look like that.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8673 ![]() ![]() ![]() |
All 4 tyres should be the same size. |
Lordackers Member Since: 28 Feb 2020 Location: West Yorkshire Posts: 32 ![]() ![]() |
There accelera iota branded, cheap and nasty springs to mind, I shall be having a word on Monday |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Check they've not fitted a Chinese wheel & tyre package as they use cheap tyres like that too |
Think the alloys are genuine based on the forum information, it had conti contacts on before they swapped them ๐ |
pawsinmud Member Since: 26 Mar 2019 Location: Hampshire Posts: 34 ![]() ![]() ![]() |
Check the tyre markings carefully, especially the load and speed index. The tyre details will be on the sidewall. As an example, the tyres on my L322 are 255/50 R20 109Y. The 109 is the load rating and Y is the speed rating. Anything less than that might mean your tyres are not legal. The handbook and the plate in the driver's door panel will show the accepted tyre sizes for yorur car. You could also try searching on Black Circles using your registration number - they are normally pretty accurate. Last resort is to ask a Land Rover main dealer.
David405 Member Since: 17 Feb 2020 Location: Cheshire Posts: 37 ![]() ![]() ![]() |
I had the same issue with my car, you'll find the contact patch of those tyres is about 235mm (how do they get away with that?) I've swapped the tyres, now thinking about the wheels. Looks like I'll be taking one off this week for a proper look. 2013 405 TDV6 Vogue SE Barolo Black
