Home > Wheels & Tyres > Tyre width
Lordackers
Tyre width
Picked up a 15 plate vogue SE on Thursday the dealer has fitted 2 new budget tyres prior to sale but I note that the rear alloys sticks out past the tyre wall, can anyone tell me if the rear tyres should be wider than the fronts? And what OEM landrover tyres sizes would have been on style 7007 22โ€ rims
Post #546354 7th Mar 2020 9:02pm
Vogue
OEM 275/40/22 and no they should not look like that.
Some RRโ€™s / Discovery 5โ€™s are being fitted with 285/40/22 as OE 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #546355 7th Mar 2020 9:05pm
All 4 tyres should be the same size. Thumbs Up There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #546360 7th Mar 2020 9:13pm
Lordackers
There accelera iota branded, cheap and nasty springs to mind, I shall be having a word on Monday
Post #546361 7th Mar 2020 9:14pm
Check they've not fitted a Chinese wheel & tyre package as they use cheap tyres like that too Whistle Thumbs Up
Post #546377 7th Mar 2020 10:34pm
Lordackers
Think the alloys are genuine based on the forum information, it had conti contacts on before they swapped them ๐Ÿ˜
Post #546383 7th Mar 2020 11:42pm
pawsinmud
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Check the tyre markings carefully, especially the load and speed index. The tyre details will be on the sidewall. As an example, the tyres on my L322 are 255/50 R20 109Y. The 109 is the load rating and Y is the speed rating. Anything less than that might mean your tyres are not legal. The handbook and the plate in the driver's door panel will show the accepted tyre sizes for yorur car. You could also try searching on Black Circles using your registration number - they are normally pretty accurate. Last resort is to ask a Land Rover main dealer.
If all four tyres are not exactly the same size, you will damage the transmission system. 2011 TDV8 Vogue SE
Post #546398 8th Mar 2020 7:54am
David405
United Kingdom 2013 Range Rover Vogue SE TDV6 Barolo Black
I had the same issue with my car, you'll find the contact patch of those tyres is about 235mm (how do they get away with that?) I've swapped the tyres, now thinking about the wheels. Looks like I'll be taking one off this week for a proper look. 2013 405 TDV6 Vogue SE Barolo Black
2007 L322 TDV8 Vogue (Gone)
Post #546439 8th Mar 2020 1:32pm
