Home > In Car Electronics (L322) > Weird speaker codes on IID
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Anyone got any clues on fixing these?
Post #546335 7th Mar 2020 6:22pm
David405
United Kingdom 2013 Range Rover Vogue SE TDV6 Barolo Black
I take it you've tried clearing the codes and re-reading? Very Happy 2013 405 TDV6 Vogue SE Barolo Black
2007 L322 TDV8 Vogue (Gone)
Post #546336 7th Mar 2020 6:24pm
lighthouse
Yes tired that, when I brought the car battery was shot so had a few codes you normally get with low voltage on the fatties but have cleared them several times keep coming back.
Post #546353 7th Mar 2020 8:59pm
Spud
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
They are telling you that three of your speakers are duff. Had the same on mine and had to go round all with ear next to them to find the duff ones.
New speakers fitted and codes cleared. 2006 4.2 SC
Post #546367 7th Mar 2020 9:45pm
DrRob
Do speakers blow and need replacing then sometimes? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #546394 8th Mar 2020 7:44am
lighthouse
does anyone know where speakers 1,2 and 8 are?
I was thinking maybe more a cable issue
Post #546395 8th Mar 2020 7:47am
lighthouse
where did you source speakers from?
Post #546396 8th Mar 2020 7:49am
Spud
The evil bay. 2006 4.2 SC
Post #546397 8th Mar 2020 7:53am
lighthouse
thanks now need to find the right ones
Post #546399 8th Mar 2020 7:54am
Spud
Once you find the defective speakers, then just remove them and get the LR part number off the back of it. 2006 4.2 SC
Post #546400 8th Mar 2020 7:56am
Bluegreygreen Rangie 2
Australia
I randomly get these codes but the sound of the sytem is always amazing so i dont think there is an issue but i might go around one by one and have a good sus on it ... Im guessing it's worth looknng over the connections to the amplifier etc which i think is in the rear left quarter pannell
Interested to see what you find
Dave 2010 3.6TDV8 Autobiography
Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #546402 8th Mar 2020 8:28am
lighthouse
I was thinking amp connectors, had look yesterday and its hard to get at and it was getting dark so decided to wait before removing all the other things you need to get to it. But it seems very dry there no sings of the water issues and mine is a late 2011.
I will have a listen today and check out all the speakers.
So I get it right there are 2 in each door, 2 in the rear pillars, sub rear left side anymore?
Post #546403 8th Mar 2020 8:30am
Australia
Mine also seems very dry in there,
Um the tweeters on the upper part of the door just inside of the rear view mirrors and there is a center dash speaker but i think it is more for the phone system sound etc... cant remember
If you use the balance / fader controlls it should be very easy to test and compare from side to side end to end etc which is what ive done in the past after seeing this code but it always tests and sounds fine to me and im pretty fussy with audio
GAP Diagnostics
Post #546406 8th Mar 2020 8:40am
Australia
Also whilst i think of it (might save you some time) is the two in the rear d pillars are only activated when you have the logic 7 setting on as i understand it 2010 3.6TDV8 Autobiography
GAP Diagnostics
Post #546407 8th Mar 2020 8:42am
lighthouse
Thanks will check all the speakers today and feedback
Post #546411 8th Mar 2020 9:34am
