Home > In Car Electronics (L322) > Weird speaker codes on IID
loltheinternet
United States 2015 Range Rover Autobiography 5.0 SC V8 Fuji White
Let me know what you find - I have literally the same exact three codes on my system.
Post #546492 9th Mar 2020 12:26am
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
Me too, interested in the outcome of this one.
Mine sounds fine as well but since I've got a day off tomorrow I think I'll spend a bit of time doing some digging 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #546637 9th Mar 2020 9:45pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I will update once testing is done, been a bit busy the last few days.
From quick test yesterday drivers door bottom speaker is not work and nor is the tweeter but the mid range is.
No idea which one is speaker 8.
Question is, is it bad speakers, bad wires or bad amp?
Post #546645 9th Mar 2020 11:33pm
Tugger
Just out of curiosity - it is a case of having to remove the door panel to get at the speakers?
Wondering if it's relatively easy to get them out, might be able to swap with the opposite side to figure out if it's the speaker itself or something else 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Fiat 500 1.2
Post #546689 10th Mar 2020 2:15pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Yep door panel off job. The big speaker at the bottom of the door unscrews, the smaller ones up by the door release are held in place with plastic welds that need to be drilled out to remove. Would be a case of drilling and using self tappers to fit a new one, not too hard.
fanders
Post #546800 11th Mar 2020 3:01pm
lighthouse
I am beging to think my door ones might not be plugged in, I have an annoying rattle from inside the drivers door. Going to try and work out how to drop the door card off later and have a look.
I do have 3 speakers with no sound so the error codes are correct.
Post #546811 11th Mar 2020 3:55pm
Bluegreygreen Rangie 2
Australia
My update,
I checked the sound each and every speaker again - Perfect... sounds awesome, Ran my gap tool and have two codes both open circut speaker 1 and 2 so who knows but im not at all worried as it lways sounds fine, I do not use the logik 7 so im wondering if the speaker codes i have relate to the two extra logik 7 speakers up in the d pillars some how with them been switched off
Interesting to see what you guys find and how you go with testing the speaker and wiring etc if need be
Dave 2010 3.6TDV8 Autobiography
Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #546943 12th Mar 2020 7:05pm
bruce
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
I have the same fault codes on my 2010SC the only speaker that actually sounds knackered is the one that the phone utilises. If I could easily find it and swap it I would. If you are not part of the solution you are part of the problem!!
Post #548579 28th Mar 2020 5:16pm
