Home > Maintenance & Mods (L322) > Suspension - car keeps wanting to go into Extended Mode
Always
******* Now fixed ******
2007 TDV8
So... I've just replaced the front air springs (one was leaking). That fix went ok, but I've still got a problem that I'd hoped would sort itself out as part of the process... funnily enough it didn't!
Having replaced the bags, I was cycling through the suspension height settings to test it all. Every time I set it to go down it decides it wants to go into extended mode. I'm constantly tying to override it... and eventually I get 'suspension fault'. Switch ignition off, then on again, fault clears and back to altering the height.
My gut feeling tells me that this is possibly down to sticking height sensors.... anyone got any opinions on this? And more importantly, can they be lubricated, or is it a replacement job...??!
Or it could be something else completely! (It had done the same thing a couple of times before I changed the air springs).
Got to be honest, I'd no idea even what they looked like until I'd googled it!!!
Any opinions / input greatly appreciated.
Rich
Post #546233 6th Mar 2020 7:44pm
DrRob
First thing to do is drill out the sintered brass exhaust valve on the compressor.
Info on here via the Wiki under Suspension https://www.fullfatrr.com/wiki/Main_Page
I’ll help you out https://www.fullfatrr.com/forum/topic23038.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #546235 6th Mar 2020 7:53pm
mjdronfield
And make sure the height sensors haven’t swung round and are upside down or similar.
I read on here they can do that when they are disconnected and if you don’t notice you connect them back up....
Never seen it or had the issue myself so can’t elaborate.
Someone else can explain better I’m sure...
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #546246 6th Mar 2020 9:29pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Yes, it looks like you have accidentally swung the sensors around be reinstalling. First thing I would do is to disconnect the sensor and swivel it around to the other side and see what happens. If worst comes to worst you have to order a new one which I did right away with the new struts when I had to change them.
Post #546257 7th Mar 2020 7:29am
Always
Hi.
To be clear, the height sensors have not been disconnected at any point during the process, so that can't be the issue.
I'll be trying the compressor exhaust valve fix today and report back. Mine is intermittent though, so unsure if this will sort it.
Post #546258 7th Mar 2020 7:50am
Always
Just feeding back with findings. Thank you Dr Rob. It was indeed the sintered brass exhaust valve on the compressor being blocked.
For the record, I did do a search, but my symptoms being slightly intermittent, and able to be overridden, didn't seem quite so severe as most of the threads that I found.
There are two types of sintered brass exhaust valves; my compressor was replaced a few years ago, and I think I now have the updated version of the compressor with a chunkier looking valve - right on top and easily accessible. I think it is an M12 thread.
Rather than drill a hole in it (IMHO it is 'sealed' for a reason), I've left mine to soak for a few minutes in frequently replenished boiling water, then dried it off / applied heat with a blowtorch (careful not to over-do it). I've now refitted it and it is lowering perfectly. Pumping up is still slow though, so I intend to purchase a replacement part to minimise stressing the compressor.
The part number for mine is LR025940. Looks like about £40 (!) but I've not fully searched yet. Any top tips on sourcing it cheap are appreciated!
Post #546273 7th Mar 2020 10:10am
DrRob
Bazinga! Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #546282 7th Mar 2020 12:06pm
mjdronfield
You prob saw my thread then where it was stuck in extended mode and I ended up drilling it out. Cos the air can’t escape fast enough to lower the car in a timely manner, it assumes there is an obstacle underneath so goes to full height.
I’ve had no issues since, but I get what you mean about not drilling it and replacing. I read somewhere it’s a service item at some point, but bet garages hardly ever do them.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #546283 7th Mar 2020 12:09pm
DrRob
I think a tiny hole is a good fix for it and a lot cheaper than what LR want.
There must be a cheaper seller somewhere Whistle Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #546301 7th Mar 2020 2:36pm
nino_nino
this is what I did with mine-
 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #546421 8th Mar 2020 11:10am
