Home > Maintenance & Mods (L322) > Restricted performance
Neilacker
Hi
I am new to the forum and hope someone can help, for the last couple of days my range rover 3.6td v8 has been coming up with warnings then going into limp mode, the warnings are restricted performance, stability control not available, forward alert not available and emergency brake assist not available. This normally happens when trying to accelerate to around 60-70 mph but sometimes less. I've had a alternator and battery fitted about 2 months ago.
Does anyone have any ideas what could be wrong or where to start looking for the fault
Thanks
Post #545813 2nd Mar 2020 8:00pm
DrRob
Welcome Thumbs Up
Ideally it needs the codes read with a diagnostic machine. There is bound to be a LR specialist in your area. Where are you? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #545826 2nd Mar 2020 9:48pm
Tooltime79
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
The first thing I would try is to check the top inter cooler hoses which often get a small tear and cause the fault you have. They can be hard to see as the go in the bends so you might need to take off (2 jubilee clips) and inspect them.
Thanks
Tim
Post #545828 2nd Mar 2020 9:54pm
Neilacker
Thanks I will check them tomorrow.
I can get my hands on a icarsoft reader if that's any use 😁👍
Post #545831 2nd Mar 2020 10:53pm
DrRob
Read codes and check your hoses Thumbs Up
Replace any split hoses with silicone versions. A few places do a kit for the 3.6 tdv8 Thumbs Up
https://www.island-4x4.co.uk/silicone-hose...34045.html
Do the lot! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #545849 3rd Mar 2020 8:25am
DrRob
Icarsoft lr2 is not a bad little reader Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #545864 3rd Mar 2020 11:23am
Neilacker
Thanks for the advice,
I will be checking the hoses in the next hour and I have managed to get the icarsoft reader to see what codes if any come up.
I've got to say this is my 2nd range rover and i absolutely love them, cant see me driving anything else 😁
Post #545892 3rd Mar 2020 5:15pm
Neilacker
[img]
Found the little Censored 😁 or at least the first one haha, I will get some pipes ordered and let you know how it goes.
Cheers
[/img]
Post #545895 3rd Mar 2020 6:27pm
DrRob
Excellent news! Get them silicone hoses on, clear the codes and hopefully job done Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #545896 3rd Mar 2020 6:41pm
Neilacker
Fingers crossed it's sorted. I've had it 3 years now and other than the alternator it's never let me down Very Happy
Post #545898 3rd Mar 2020 6:55pm
TDSIX
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
Well done. You are lucky.. last time I got 'restricted performance' and limp mode, it was a turbo actuator (engine out £,£££). 2010 FF 4.4 TDV8 Vogue - Gone
2007 FF VSE 3.6 TDV8 - Gone
2011 RRS HSE 3.0 TDV6- Gone
2003 FF TD6 Vogue - Gone
2006 FF TD6 - Gone
2007 FF 3.6 VSE - For sale
2011 FF 4.4 TDV8 - Current
Post #545920 3rd Mar 2020 10:21pm
Neilacker
Got my new pipes fitted and all is as it should be, no more warning lights or limp mode 👍😁
Thanks for the advice 👍
Post #546734 10th Mar 2020 9:01pm
DrRob
Post #546735 10th Mar 2020 9:02pm
